Steering gearbox install
Old Mar 28, 2008 | 12:17 AM
GEDaggett's Avatar
1994 E320 (current)
Any one out there got diagrams, instructions and or torque specs for replacing a steering gearbox for a 94 E320. I scored the part for $115.00 (shipped) with 6 mo warranty and I am going to crack into it next weekend.
Old Mar 28, 2008 | 12:46 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
$115? Is that a rebuilt or used?
Old Mar 28, 2008 | 06:31 PM
GEDaggett's Avatar
1994 E320 (current)
it's used. 6 month warranty and a 30 day return.
Old Mar 28, 2008 | 07:06 PM
forcedawd's Avatar
W124, W220 S500 4matic, W140 S500, CLS55 AMG
here you go -
File Type: pdf
Old Mar 28, 2008 | 08:32 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
These are adjustable, are you sure the box is bad?
Old Mar 28, 2008 | 11:51 PM
GEDaggett's Avatar
1994 E320 (current)
Pretty sure. I got a lot of lane dancing going on at 45mph or better. I put the car up on the jack stands and went over the entire steering and suspension set up. If the wheels are turned all the to the right there is about 1/2 inch (if you use a bit of force) of play. If you move the wheel all the way to the left there is about 2 1/4 inches of play. All of the bushings and linkage is in good shape no movement on the tie rods or ball joints. They are all tight. The movement is coming from inside the shaft of the gear box. If I can adjust that out that would be awesome. How does one go about getting the procedures for that?
Old Mar 31, 2008 | 11:29 AM
GEDaggett's Avatar
1994 E320 (current)
Originally Posted by forcedawd
here you go -
thanks for the Info. This helps tremendously.
