Moisture inside the headlight?
Old Mar 28, 2008 | 01:41 PM
STLe320's Avatar
95 e320...sold the rest
The inside of my driver's side headlight has a lot of moisture on the inner lens. I'm not sure why...maybe a bad seal?
Is there anyway to get it out without taking the light out? I have a show tonight and it looks HORRIBLE!
Old Mar 28, 2008 | 03:27 PM
forcedawd's Avatar
W124, W220 S500 4matic, W140 S500, CLS55 AMG
The only thing I can suggest for removing the condensation by tonight is to remove the back cover and let it air dry.
Ultimately, you will need to remove the light and seperate the lens from the mounting frame. Clean off all of the old adhesive/sealant and then get yourself some clear RTV and reapply around the lens and frame. Use some spring clamps to hold the lens onto the frame for about 24 hours then reinstall onto the headlight housing.
There are also 2 gaskets per headlight that you can replace as well. One is located on the back access cover. The second is between the headlight housing and lens frame.
Sam
Old Mar 28, 2008 | 04:29 PM
STLe320's Avatar
Thanks alot. For now, I'll just let it air-dry.
I guess tomorrow I'll reseal it and whatnot!
Old Mar 28, 2008 | 10:34 PM
ZorroAMG's Avatar
Enzo, my Benzo
Back cover off, heat gun/hair dryer to dry it out...
Old Mar 29, 2008 | 04:44 AM
ZedStyle's Avatar
Youngtimer
... or new lights...?
Old Mar 29, 2008 | 05:36 AM
ZorroAMG's Avatar
Enzo, my Benzo
Meh, I've given up on THAT battle....
Old Mar 29, 2008 | 12:01 PM
STLe320's Avatar
ha..ha
sorry i'm phucking broke
