90 300E 3.0L Belt Tensioner Problem
1990 300E 3.0 White
The other day I was driving about 70mph when I heard a mild boom and all of my dash lights went on. The car drove fine but overheated so I stop and had it towed. Turns out that the fan belt broke.
I have replaced the belt but the tentioner doesn't tighten. The bolt that I understand tightens the tentioner just turns and does nothing.
Do you think the tensioner is fried? If so, how hard is it to change and does anybody have any instructions?
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
1990 300E 3.0 White
Thanks![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I found detailed instructions on another site.
Seems the tension rod broke because some fool didn't tighten the tensioner (I guess). In any case, the tension rod was around $18.00 plus shipping so it wasn't that bad. I took time to replace the water pump, tensioner, dampener & rod, plus do a complete tune-up.
Anybody thinking about doing this job should know that it's pretty involved and I give it a 5 out of 10 on the difficult scale.
I plan on running a can of SeaFoam next. 1/3 down the throdle body, 1/3 in the tank and once I've burned all of the gas... finally 1/3 in the crankcase for 50 miles then change the oil. I did this on my 96 Mercury Grand Marquis V8 and the car runs like new. Did it on my Lexus LS400 with the same results. Incredible stuff.
1 Post
It changes all the time
I'm glad to hear you got your problem solved, but I must admit you peaked my curiousity. What made you think that you could keep driving when all the lights on your dash came on?
