18x10.5 on a W124? Sure, come on in!
Just thought I'd try out some wheels I have for sale before they're gone. I knew that they wouldn't tuck under the fenderwells, but it was worth a shot. There's actually a lot of clearance inside, around 3 inches. What that seems to indicate is that if these wheels tucked in a bit more (they're ET20) and if you didn't mind increasing your negative camber some they would fit with some rolling. It also indicates that the matching 18x9 ET20s that I have for the front would also fit with AMG spacers and some mild metal work. I suppose that buying a pair of narrower BBS outer shells would work for the rear as well to eliminate some of the work.
Anyway, just thought you guys might get a kick out of these pics:
![](http://img.photobucket.com/albums/v217/ramblux/speeline_on_w124_1.jpg)
![](http://img.photobucket.com/albums/v217/ramblux/speedline_on_w124_2.jpg)
How much more room do AMG spacers give? I'm positive that my 18x9 ET20 would fit the front with some work. If I don't sell the wheels they might become a long-term project to eventually make them fit. haha
lots of cars
Actually I'm wrong, 18x8 with a +38mm offset would have a 6" back space so 18x9 with a 30mm offset should fit without expensive mods other than fender rolling or you you can still get a 40mm offset and use 10mm spacers..
You know what. I have a barrel from a 3pc wheel and im going to measure the backspace and see what i can get away with...
