By the way....
Old Apr 24, 2008 | 09:41 PM
YNVDIZW124's Avatar
lots of cars
By the way....
I keep forgetting to post this for a while (years) but if you don't want to reach to open the door on your passenger side just tap the sunroof switch up two times and all the doors unlock. Also, I would disconnect the cruise control linkage if the lever or relay is faulty or the car is just old. The car dangerously accelerates at random times when it goes bad...
Old Apr 25, 2008 | 12:59 AM
starcar's Avatar
1994 E320
Thanks for the info...it's good to know these kind of things.
Old Apr 25, 2008 | 01:59 AM
drin's Avatar
89' 260E
Tried doing the same to my car a while ago.. didnt work though..
Any other input in doing so? Reaching for the door opener on the passenger side is really a pain..
Thanks.
Old Apr 25, 2008 | 02:08 AM
mr300ce's Avatar
1990 300CE
Unhappy
Tried it on mine with no luck.
I have aftermarket alarm and door lock. Key fob button won't unlock while car is on (normal) so yes, letting someone into car while running is a chore.
Old Apr 25, 2008 | 02:33 AM
YNVDIZW124's Avatar
lots of cars
Maybe it doesn't work on all cars? I have a viper 550 alarm on mine and it does it everytime i tap it twice. I can open the doors when the ignition is on and the car off or when it's running at any time.
Old Apr 26, 2008 | 05:43 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
hu good to know ................that clears up alot with the random pick ups with speed and the random idle i hope
Old Apr 26, 2008 | 09:12 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
All 4 doors always unlocked when I turned the key to unlock the driver's door. How do you get in the car without unlocking all of the doors? They must have changed things for different years.
Old Apr 26, 2008 | 10:09 AM
190E 16V's Avatar
1987 560SL
Sunroof switch thing does not work for me either.
Old Apr 26, 2008 | 03:59 PM
CDP's Avatar
CDP
W124's
LOL...
The Sunroof door unlocking feature DOESN'T work on W124's.
Old Apr 27, 2008 | 12:27 PM
neanderthal's Avatar
how about this one instead.
lock your drivers door then unlock it. that will unlock all the doors.
Old Apr 27, 2008 | 01:23 PM
ZedStyle's Avatar
Youngtimer
if i only turn the key about half way, only the drivers door unlocks, all the way unlocks all doors...
Old Apr 27, 2008 | 02:54 PM
AzzMan's Avatar
'94 E320
So just turn the key all the way.
Old Apr 27, 2008 | 03:35 PM
YNVDIZW124's Avatar
lots of cars
No ***** all the doors unlock when you turn the key all the way.... When I turn my ignition on or close my door all my doors lock for some reason and when I have to pick someone up I had to reach over to unlock the doors because locking and unlocking my door takes too damn long..
LOL...
It works on mine ???
I'll make a video of it...
Old Apr 27, 2008 | 03:52 PM
ZorroAMG's Avatar
Enzo, my Benzo
Your system isnt factory, YNV, stop comparing it to the OEM system that DOES NOT lock automatically when you drive.
It's your aftermarket system that causes the sunroof to unlock your car too.
Factory doesn't do any of that.
Old Apr 27, 2008 | 03:56 PM
ZedStyle's Avatar
Youngtimer
yes i know, i was responding to shdoug's question as to how to go about unlocking only the driver's door.
Old Apr 27, 2008 | 04:00 PM
AzzMan's Avatar
'94 E320
It shouldn't take long at all, unless your aftermarket system changed the locks 10000000% so that every single thing was different, you can pull your lock up on the drivers side front door and unlock every door that way, then push it back down when whomever you're picking up gets in.
Old Apr 27, 2008 | 04:02 PM
YNVDIZW124's Avatar
lots of cars
That's why i said..."Maybe it doesn't work on all cars? I have a viper 550 alarm on mine "
I was wondering if it worked on other cars with alarms....
Old Apr 27, 2008 | 04:40 PM
shdoug's Avatar
Thanks! I never knew that.
Old Apr 27, 2008 | 06:50 PM
ZorroAMG's Avatar
Enzo, my Benzo
I have the same alarm but mine doesn't do that....I guess it depends on what the installer did, or the accessories he hooked with it...not a bad alarm! Does yours go off by itself sometimes? Whats your sensitivity set at?
EDIT:
I have the 5002 alarm..
