AMG Kit installation, need mounting hardware
Located a new AMG gen 2 bumper cover, some side skirts and an AMG ducktail, but have no mounting hardware for the bumper and skirts and I still need a rear bumper.
Gonna do this to the white Sportline, lest the black one start to look like Phamtasticar or Benzo knock offs...everything they've done...I like.
So, the AMG kit is going on the white Sportline...and I am going to keep it two tone. That is what it would have been if it came new from Mercedes with this piece. I can always paint it white later.
17x7.5 AMG 5 spokes arrived today. leaning towards Pilots sized per the definitive thread. Anyone think I'll have any rubbing issues? I am running the stock Sportline suspension and would like to stay there.
I need mounting hardware and lights for the bumper cover and mounting parts for the side skirts. Since I have no rear bumper yet, I will likely not mount the skirts yet. Gonna call Rusty and see if he can tie me up.
And if anyone sees an AMG gen 2 rear bumper cover, I'd sure appreciate a heads up.
Already installed tint, stock bose audio system maintained and updated via Becker...and First gear start module soon coming.
W124's
the AMG GenII bumper does not come with all the necessary hardware for an proper installation.
There are 6 bolts total you will need to remove from the back portion of the bumper to remove it from the car.
For the front bumper you will need to drill out the rivets which hold the support brackets for the bumper which bolts onto the chassis of the car.
There will be 8-10 Rivets total you will need to drill out for the front bumper alone. Retain the metal plate on the outer part of the front bumper and use them for the AMG GenII front.
Damn, I wish I took pictures of my installation process.
Anyways, Simply go to your locate hardware store and pick up a set of nuts, bolts and washers. I believe I used a 1" long bolt with a 11-13MM socket head. Since you have the metal plates on the outer part of the bumper, use the washer in the inner part inside of each bracket. You'll understand what I'm talking about as soon as you start taking apart your car. I will elaborate more on this subject later.
As for the sideskirts you will retain the OEM bolts on your sideskirts now. You will not need to purchase any hardware for this part. Everything bolts in perfectly.
the AMG Driving Lights for the Front Bumper will be the hardest part to get for your car. I would suggest in getting C36 Fog lights instead and just buy 8MM bolts (5 total per side) along with washers and nuts. Bolts must be about 1/2" long.
- Chris
Thanks all,
Write up very helpful Chris, any chance of a link to a good light choice?
(Thanks 2Phast) All white may be the way to go here although I may stay two tone until a rear bumper is found.
W124's
it'll be VERY expensive though!
Also, Paint everything white.
Bought the lights, thanks ForceDawd!
Chris, it is looking like "all white" is the way to go, BUT, I have worries about rice-burner-look if I go all white. Your car looks GREAT with a blacked out grill, I am not as sure I shouldn't retain some of the original nic nacs like chrome/black grill. Flat hood badge is certain, white out grill...not certain.
Also, is the rear bumper the 'hard to find' piece in this set? It'd look bad with side skirts but no rear bumper, right?
W124's
A complete white AMG GenII kitted W124 would look fanatic IMO. I'll dig up some pictures for you to look at when I get home later this evening. Its time to talk you into some mod ideas.
Also, Keep in mind when you get the rear AMG GenII bumper you will need the 1994-1995 Rear Impact strip. It's only around $150 or so from the dealership.
By the way - The car won't look bad at all with just the sideskirts and front bumper. Zorro here only has the Front Bumper and Ducktail...
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
AMG was a custom shop and did whatever the customer desired.
The first AMG 320CE widebody was done in white with the cladding and the kit color matched.
The grille was left chrome and the bumper impact strips were black.
I'm looking at a picture of a later face lift E36 coupe, which sure enough has contrasting cladding and no AMG body kit.
You could have gotten the kit, the performance options or both....all up to the owner
Thanks RBYCC, so these are choices! I think a full white-out is in my future after seeing atobahn's car.
Doesn't look good for scoring an AMG back bumper anytime soon, so I am open to replicas / suggestions...I want a space filler for this wave of work.
Wald is about the only manyfacturer still making W124 kits.
Erubeni had an AMG look alike, but they went out of the kit business last year...
http://www.wald.co.jp/english/catalo...4_v4/w124.html
good find man, hurry up and install...!
i'm partial to the two-tone myself, and left my car that way when i put the kit on. I have never seen a WHITE car that is PERFECTLY matched, if just the cladding is painted to match... you can always see that the paint will look different. if you look at more pictures of the atobahn car, you can tell the slight difference, which might be more obvious in the flesh. darker colors blend in much easier, but for me, i couldn't afford to re-paint the whole car, so i kept the two tone.... just something to keep in mind! either way it will look sick.
I searched around and found some pics of atobahn's ride where the paint is not so great. If I go all white, I will likely shoot the whole car.
Zed, do you have loads of pics of your ride? I'd like to look at side shots etc, because staying grey would certainly save come bucks. And did you go Wald V4?
He did the WALD EX kit. It's more subtle than the V4.
I recommend keeping the two tone. On your car, I like it. and it will definitely save you money. But in the spirit of color-matching, you will probably want to have your entire lower half resprayed at the same time to make sure the kit matches the old cladding. If I ever get a body kit, that's what I will do.
If you get a painter who knows what he is doing, he'll take a part from the car and adjust the paint for an exact match....
Or he'll shoot a test match and adjust from there...
Painter did that when I matched the Fald EX and bumper impact strips to the twenty year old shell gray cladding.
Good thing is even if slightly off, and I mean slightly, the surfaces are such that you really can't see a flat to flat surface match !
this thread has some if you scroll down:
https://mbworld.org/forums/showthrea...931&highlight=
For the bummpers, i agree fully... but for the cladding, when matching paint, it becomes a lot tougher... even half a shade off looks quite noticeable when it runs a foot high across the length of the car...
I imagine if you have a full bumper replacement like the AMG Gen II, there's not much extra labor involved with just having the side cladding sprayed at the same time. Surface prep isn't terribly difficult because the surfaces are relatively flat. I would just rather have it all done at the same time to be sure.
https://mbworld.org/forums/showthrea...570&highlight=
That is what I meant...matching the kit to the contrasting color of the cladding.
Color match to the body would be possible but a bit more difficult.
There still will be a very slight difference due to the different material, but not noticeable.
