124 Auxilary Fan
124 Auxilary Fan
After replacing radiator(cracked at upper rad. hose nipple) water pump , thermostat, fan belt and relay, my 1988 300CE auxilary fan will not turn on. I removed the fan from the vehicle and it works with 12volts hooked directly to it. I am not getting any current to the Black w/white wire at the ceramic resistor and the A/C will not get cold. Help?
