starting problem w124 e320 1994
I'm having a strange problem with my 94 w124 e320. the car won't start when it's cold. there is no pulse from the fuel pump. when the weather is warm, there is pulse from the fuel pump and the car would start right away. before i got to this conclusion, i went ahead and changed a fuel pump relay, crank sensor, tested the fuel pump by direct wiring from the battery.. took the car to the dealer, the dealer diagnosis was that the car is having a problem with the ignition component, went ahead and changed that part, yet again when it's cold I'm having the same problem.
any suggestions?
regards
Mark
any suggestions?
regards
Mark
