key won't turn
Old Jun 15, 2008 | 10:02 AM
cam346's Avatar
2010 ss and 2009 cts-v
key won't turn
ok could this be a lock cylinder . put the key in to start and it won't turn. i wiggle the key and it turn on. i check this again this morning and it started right up. my car is a 95e320. is this common any help would be helpful thanks
Old Jun 15, 2008 | 10:21 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Yeah, sometimes the wheel position will prevent the key from turning, just play with the wheel with the key in and you will find the position that lets you turn it on.
Old Jun 15, 2008 | 10:26 AM
berti_00's Avatar
2016 Cls63s AMG
move your wheel left and right while your turning the key.... you'll get it
Old Jun 15, 2008 | 03:40 PM
STLe320's Avatar
95 e320...sold the rest
make sure your car is all the way in park as well
but it's most likely the steering wheel position
Old Jun 15, 2008 | 05:11 PM
appatula's Avatar
95' AMG SeeThreeSix
If above fails....... the tumblers are jammed and a little force is needed to dislodge them, try hitting the key with a hammer into the lock if that fails just force the key clockwise with pliers, not to the point where the key is going to break but enough pressure to dislodge the stuck pin.
Old Jun 15, 2008 | 05:20 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
i second that motion.
The steering wheel and shifter position are common things your probly would have checked before posting a thread about this.
I had the same problem when I first got the car. It would be fine sometimes, and other times it would be impossible to get started. I had read up on bump-keys and how they work so i gave the mallet trick a try. Sure enough a little tap into the ignition fixed the problem. I sprayed a little slick 50 lubricant in and it hasnt stuck in almost 2 years.
Old Jun 15, 2008 | 05:29 PM
appatula's Avatar
95' AMG SeeThreeSix
I also want to reassure you that I wouldent recommend something I haven't tried myself, so I second Rivcal4life. I have tried this while "stuck at college" and the above fixed my problem. I've been good for about 6 months now with no stickage.
Old Jun 15, 2008 | 08:30 PM
cam346's Avatar
thanks guys
Old Jun 16, 2008 | 05:45 PM
mr300ce's Avatar
1990 300CE
Repair BEFORE getting stranded.
Mine did it too. I got a new ignition lock from Mercedes for $85. NO TOW for me.
It was simple to replace it (search this forum for instructions), and when it came out, I found several pieces of the old one jammed up in there.
