Lighting System is Screwed UP! Possible culprits? Its a Mystery. come play!
Here is what i did:
With the installation the new headlights, the wiper motors were removed. I let the wiper moter plugs stay tucked away behind the headlight on both headlights.
I installed an aftermarket pioneer head unit and the illumination wire was not functional with the dash lights so i had to wire the lights into the headlight fuse. This now makes my dash lights blink with the turn signals when my lights are off.
I then found left over wires, one of which was this:
Someone suggested that this was a turn signal ground (a possible suspect). But where does it go?
The symptoms of the car is as follows:
1. When the lights are off the turn signals work, but the dash lights blink (im obviously tripping the lights over the fuse.
2. When the lights are on, only the driver side marker illuminates and neither turn signal will activate. Also the cluster arrow indicators are both on.
3. All of the rear interior lights remain illuminated at all times. This includes the rear driver side door courtesy light, the rear passenger side courtesy light, and the rear roof light.
Anyone ever heard of any of these problems?
EDIT: So i tried removing my directly wired illumination wire, and it does not change anything. The lights are still severely screwed up. Now when i use the turn signals when lights are off, the fronts work but ALL rear lights blink. tail lights and turn signals.
I have no clue!
The headlight swap shouldn't have created this. First remove the head-unit to lighting fuse connection. Did anything change? Please post result.
Meter the mystery wiring connectors to ground. That will verify it is a ground or hot. You may need to test with the lights on and off.
Where do these mystery wires live? Behind the head-unit? Photo all you see with the connectors.
that pic you posted, i'm 95% sure that i left that wire disconnected when i just installed my head unit, infact i'm 99% sure i left it disconnected, so i don't think that would be your problem.
the illumination thing is weird, when i had a dvd player in the car, i hooked up the illum wire to the wrong wire in the harness, so when i turned on my headlights the screen would go into aux mode or something. undo that wire, and just leave the speakers, power, ground, connected, and see if the car is still acting funny.
After all was installed, i started to notice all the funky things happening.
I will snap a picture of what the stereo wiring looks like now.
I have no clue!
