1992 400e
Old Dec 23, 2002 | 03:14 AM
cdawg50's Avatar
200 c280 sport
1992 400e
Need help. Thinking of picking up a 400e w/ 135k for about $8k. What should I look out for and/or problems to expect. Any help will be greatly appreciated. Thanks
Old Dec 29, 2002 | 08:20 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
This seeme to be to good to be true. A 400E for $8k!!
Check the car's history, if not available ask yourself why. Check the numbers of preowners. Check for accidents!!! Check for signs whether the mileage is right. (check pedals, scratched windshield, used up seat covers, steering wheel tells also stories about the real mileage. Check for corrosion especially lower doorpanels inside, car jack pipes behind the plasic cover, the inside of front fendors (under the hood), rear wheel arches.
Check for oil losses through the head gasket, oil losses of the powersteering, check A/C function. Have cylinder compression check done. Have someone professionally check the auto transmission.
if all this seem ok go for it. But the most expensive things to fix I discribed are A/C, transmission, head gasket and foul comprssion.
