FS: 1991 300E 2.6 $2400
This is a w124 that has a bulletproof M103 motor, perfect for a dailydriver and the classic lines of the W124. I have changed the oil every 2,000 miles with Mobil 1. Also I just changed the transmission fluid and filter. The car has newly installed 20% tint and has an Alpine head unit with JL audio speakers installed profesionally. The Carlsson wheels are NOT included, it will have the stock wheels. It has the tested over time MB tex interior. The following items have been changed within the last year:
valve cover gasket
intake manifold gasket
camshaft sprocket
timing chain
chain tensioner
O-Ring seal
chain tensioner guide rail
chain guide (left inside)
chain guide (left outside)
front crankshaft seal
crankshaft gear
oil pump chain
oil pump gear
cam gear cover seal
serpentine belt
overflow tank
radiator hose
coolant overflow tank hose
coolant hoses
thermostat hose
oil pump gasket
oil pump chain lever
Heads re-surfaced
5-angle valve job
(4) Blistein HD shocks
(4) MB floormats
This car will surely go many miles more with the future owner. I have spent alot of time and money, but am getting ready to fund another project and need a little extra cash. The only cons are: the paint is starting to fade but not noticeable 6ft. away also the A/C has a leak somewhere, but the A/C compressor came back with a charge of 220 volts so its probably a line. The mileage is 187,000
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics002.jpg)
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics003.jpg)
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics004.jpg)
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics005.jpg)
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics006.jpg)
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics007.jpg)
valve cover gasket
camshaft sprocket
timing chain
chain tensioner
O-Ring seal
crankshaft gear
oil pump chain
oil pump gear
cam gear cover seal
serpentine belt
overflow tank
radiator hose
coolant hoses
thermostat hose
oil pump gasket
Heads re-surfaced
5-angle valve job
(4) MB floormats
![](http://i134.photobucket.com/albums/q109/tashtusha/Mercedespics008.jpg)
