Pin 7 code 9,11
Old Sep 28, 2008 | 11:47 PM
childofjuly's Avatar
1995 E 420
Pin 7 code 9,11
My car is suffering from irregular rough idling. I have put together a DTC code reader and pulled codes 9, and 11 from Pin 7 (EA/CC/ISC).
Code 9 =Left rear axle vehicle speed sensor (L6/3) from ABS/ASR control module (N30/1)
Code 11 = Fuel safety shut-off to LH-SFI control module (N3/1), Closed throttle recognition signal to LH-SFI control module (N3/1)
does anyone know what this all means or can someone point me to the right direction??
my car is a '95 e420 without ASR...
Old Sep 29, 2008 | 11:10 AM
hineywineries's Avatar
It changes all the time
You didn't mention having a MIL. Considering those are disparate codes, I would suggest a close exam of the wiring harnesses. Your car falls into the years od biodegradable wiring.
Old Sep 29, 2008 | 02:28 PM
1995 E 420
Thanks for the reply! My upper wiring harness was replaced 10 moths ago along with my water pump, plugs, wires, and cap..
