93 300ce 3.2 stalling upon startup and eratic idle in park?
Old 10-07-2008, 02:33 PM
mattdoh's Avatar
1993 Mercedes Benz 300 CE
Hey everyone, I just bought my 1st Benz. I always likes the coupes and I've wanted a CE model since I was 12. I got a bargain too! Anyway, she has already had a harness put in, as well as head gasket, radiator and thermostat.
The issue is that in park the car idles between 5 and 2500 rpm. In the morning the car hesitates from a stop, idles rough and sometimes stalls a couple times.
As a former Honda enthusiast, these issues are either a crank sensor, tps sensor or an ignition issue.
Please help, and btw I'm in Chicago and would like to attend a meet.
Old 10-07-2008, 03:11 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Ignition Wiring, OVP relay, Plugs, Rotor/Cap (if you have the same m104 my 90 CE does)
Old 10-07-2008, 08:07 PM
Chinny4290's Avatar
1994 C124 E320 Coupe - 1975 W116 280S
He has the 3.2 M104 so it's coil-over ignition system, and not distributor cap and rotor.
OP, have you done simple things like the wires, plugs and OVP relay as aforementioned? Also consider the ignition coils, fuel pump, fuel filter.
Sometimes when you replace the wiring harness, the same awful wiring is on the throttle body and you have to replace the throttle body/actuator on top of the wiring harness.
It also can be an ECU issue. And there's also an idle control valve. Is your CEL on, and have you gotten any codes?
Quick Reply: 93 300ce 3.2 stalling upon startup and eratic idle in park?
