Temorarily Disable Check Engine Light?
Old Oct 14, 2008 | 03:22 PM
CDP's Avatar
CDP
W124's
Temporarily Disable Check Engine Light?
Is there a way to temporarily disable the check engine light from coming on besides disabling the battery?
Old Oct 14, 2008 | 03:24 PM
berti_00's Avatar
2016 Cls63s AMG
yeah with a computer... some shops did it a few times for my dad. they just rested everything.
but battery works too witch you already know
Old Oct 14, 2008 | 03:42 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
unplug the diagnostic module. or remove the bulb.
Old Oct 14, 2008 | 03:48 PM
donjuan45i's Avatar
S500
take the car to any shop that has a diagnostic OBDII scanner, they are most of the times willing to shut it off if you want. some charge tho for diagnostic, maybe tell them you just want them to erase the codes, maybe they wont charge you for a full diagnostic
BUT Some autoparts store also give a free diagnostic such as autozone and advanced autoparts, not sure if they will turn off the light though. I actually think they have a policy against it.
EDIT: just noticed that your car is a 95 I think OBDII is just for 96+ (autoparts stores also I think only carry OBDII) your going to need OBDI any small shop that runs computer diag should have it
or just do the battery trick
Old Oct 14, 2008 | 04:05 PM
CDP's Avatar
CDP
W124's
Where and how can I do that?
I tried removing the instrument cluster in the past to remove the bulb but I couldn't get it to come out of the dash. Is there a fuse for that light or something? or maybe I should disable the entire instrument/light for the instrument cluster?
Oh and I'm just trying to find out so I can smog my car. lol
Old Oct 14, 2008 | 04:32 PM
STLe320's Avatar
95 e320...sold the rest
My check engine light has been on for almost 3 weeks, and nothing is wrong? Another thing, the yellow light for a missing light comes on periodically, and I don't have a light out?
Old Oct 14, 2008 | 06:16 PM
ZedStyle's Avatar
Youngtimer
why is the light coming on?
Old Oct 14, 2008 | 06:20 PM
CDP's Avatar
CDP
W124's
Unknown at the moment.
It comes and goes since a few months after I bought the car and it's been running fine however.
Now I'm curious as to how I can disable the diagnostic "module"
Old Oct 14, 2008 | 06:21 PM
ZedStyle's Avatar
Youngtimer
that's weird... would have been if you could read the codes to figure it out, but if it keeps going away that's just strange...
i would pull the bulb though, if you could find someone to help you get the cluster out...
Old Oct 14, 2008 | 06:26 PM
CDP's Avatar
CDP
W124's
Last time I recently hooked up the car to the Star Diagnostic there was one minor problem but I forgot what it was specifically.
I wonder if you can temporarily disable the instrument cluster entirely? or just the warning lights. I haven't been able to check yet - I've been in the office all day.
Old Oct 14, 2008 | 07:17 PM
If you are trying to do smog then the light has to come on for start up and then go out.
To remove the cluster you have to disconnect the speedo cable from the rear of the transmission to give the cable slack.
The diagnostic module is most likely behind the Instrument cluster and down a little.
If you just need the code cleared to get through emissions then go to the diag. terminal by the battery on passenger side under hood. There is a button. Push it for 2-3 seconds and count the blinks. This is the code. Then immediately push the button for 8 seconds and code will clear. Must do this after every code one at a time. When the light blinks once no codes are present.
cycle the key and go get your emissions.
good luck.
Old Oct 14, 2008 | 07:21 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Just put a piece of electrical tape over it. Or if you really wanna get technical, print out a picture of it with the light off so the words are still there.
oooorrrr.
Pay the smog shop an extra 10-20 bucks. Just go to a smaller shop and talk to the guy. I got mine passed with the smog pump bypassed and a failed gas cap.
Old Oct 14, 2008 | 10:24 PM
CDP's Avatar
CDP
W124's
Already got the smog taken care of - Passed.
I just reconnected the battery.
Old Oct 14, 2008 | 10:28 PM
berti_00's Avatar
2016 Cls63s AMG
good for you phammi boiii
Old Oct 15, 2008 | 12:10 AM
oneill_1's Avatar
MB 300E | BMW M Coupe
chris, you coulda cleared the error codes that were being thrown. i am not sure if my home made tool woulda worked but if you need it cleared again, hit me up...you know my aim.
good luck.
or what he said^
-OG
Old Oct 15, 2008 | 03:26 AM
CDP's Avatar
CDP
W124's
I never see you on AIM anymore galindo!!!
Old Oct 15, 2008 | 10:53 PM
Federic0W124's Avatar
1992 400E
i just pulled mines out. goddamn upshift delay code.
the cluster came right out...no speedo cable to deal with
Old Oct 16, 2008 | 02:25 AM
Chinny4290's Avatar
1994 C124 E320 Coupe - 1975 W116 280S
If you have a 16pin diagnostic module next to your battery that looks like this:
Hold that button next to the 2 (The quick diag button) for 10 seconds, with the battery turned fully on, but no engine.
Resets the CEL computer and light is gone. However, it turns back on every 5 key cycles if you have an ongoing problem. A nice temporary tip.
I'm surprised none of you knew of this.
Old Oct 16, 2008 | 10:36 AM
Also want to add that the v8 w124's have an electric speedo, so do not try this on the other models.
Old Mar 27, 2009 | 10:46 AM
Chinny4290's Avatar
I believe all W124s have electric speedos.
Old Mar 28, 2009 | 02:10 AM
YNVDIZW124's Avatar
lots of cars
My car doesn't have a check engine light but you wanna know a trick? Change the check engine light to the bulb out to out socket. Just say that light turns on because you have a short on one of the bulbs when it's actually your check engine light. Some smog guys turn on the car and check if you took out the bulb because all the lights come on when you turn the key to the acc position.
Old Dec 27, 2014 | 03:31 PM
jameyemail's Avatar
2007 c230
diagnostic module on 2007 c230?
reading through the temp ways to turn off the CHECK ENGINE LIGHT....
I went out and looked on her 2007 c230 and couldnt find anything that looked like the picture someone posted of the 16 pin module with the push button on it. Can someone please help us?
Old Dec 29, 2014 | 05:15 PM
jameyemail's Avatar
2007 c230
not trying to cheat anyone!
Just trying to get girlfriends car through deq/smog.
any suggestions?
