1992 400e with CEL code 8 & 27 Please help!
Old Oct 28, 2008 | 02:05 PM
chien903's Avatar
w124 400E
Hi!
Last friday, CEL on my 400E came on all of the sudden. After checking with the on board diagnostic. I get Code 8 and 27 which is
8 Coolant temp sensor-open or short circuit.
27 Coolant temp sensor deviation between sensor ciruits 1 & 2.
The car ran fine but can anybody please tell me how do I fix these two codes? And also the location of the Coolant Temp Sendor. Is it the sensor on the reservoir tank?
Thank you in a advance!
Old Oct 29, 2008 | 06:01 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
It most probably is the dual temperature sensor on top of the motor block. It is a 2-wire screw-in type sensor. I'm not sure where exactly the sensor sits in the V8, but in the I6-engines it sits on top of the block next to the rear wall/driver side
