Front tyre wear
Old Jan 9, 2003 | 03:49 AM
babington's Avatar
1994 E280
Front tyre wear
Hello all,
I have a 1994 280E with 230k kilometres on the clock. The front drivers side tyre occasionally makes contact with the fender upon hitting a bump when when turning into a low speed corner. A driveway with a pronounced kerb will do it.
The suspension has been checked out and the side that scrapes is about 1 inch lower than spec. The other side is OK.
Tyres on 16 inch mag rims are standard size.
I find it hard to believe that this could be caused by a 1 inch drop in ride height. Anyone have any ideas??
Old Jan 9, 2003 | 11:24 AM
KWiK's Avatar
2002 C230 : 2007 C230
Are these standard MB 16" wheels? If not, then a poor offset could still cause rubbing like that.
Old Jan 9, 2003 | 08:12 PM
chupper's Avatar
ACtually, if i am right, the oe wheels are 15'', not sure about the 280 though.., my 300e is 15''
Old Jan 9, 2003 | 08:30 PM
babington's Avatar
1994 E280
as far as I am aware the wheels are standard MB 16" alloys, tyres are standard 205/55/16
Old Jan 9, 2003 | 11:00 PM
chupper's Avatar
yea, i got my info from tire rack. they reported 195/65-15 for the 94 280E , but it may be different, or tire rack might be wrong completely...
Old Jan 10, 2003 | 03:21 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Hi,
if one side is lower than the other there definitely something wrong with the car. The options are:
*Broken main spring. Often hard to see by only looking at it, since the either the last top or bottom turn breaks and may lower the side, by that magnitude.
*the main axle joint may be worn out. Sorry but I dont know the exact english expression for that part. It sits right behind the axle assembly and basically connects the wheels to the body by means of a "bearing". If this is worn it sometimes makes screeching noises when turning the steering wheel, and it lowers the worn side of the car, may be not exactly a whole inch, but using 16" rims, maybe with the wrong offset could cause the problem of rubbing against the fendor.
