windshield squirters not working...
1991 300E 63K miles in Ice Blue
'91 300E only 70K miles with Euro (no wipers) headlamps.
I replaced one of the washer pump motors some months ago as wall as the sealing grommets but now the motors do not activate from the push lever on at the steering pod. Fuse #2 is good, and no other known electrical malfunctions.
Is there a relay that activates the windshield resovoir pump motors? Any ideas?
thanks
thanks
Do you have a test light? If so unplug the washer pump and insert the test light in place of the pump, then activate the washer and see if the test light lights up. If so then it's your pump. The pump is driven directly from the turn signal switch.
thanks
