Fuse/Emergency Flasher Malfunction/Secret Button
Here is the problem, since then while i am driving i hear an intermittent clicking that goes for 5 -20 seconds. The sound comes from the dash, under the steering column and sounds like the clicking sound that the emer. flashers make. After a short period of time it stops. Only to start up again a few seconds or minutes later. The emergency flashers on all four corners of the exterior lenses flash when this is going on. The Red toggle flasher on the dash does not flash however. Has anyone experienced this issue? The fuses are ok, and i have never had this malfunction prior to removing those fuses.
Under the drivers dash is black plastic shield that covers the hole under dash section. To the left of the steering column is a tiny push button. Does anyone have an idea what it does. I have pressed it while investigating the previous issue and it seems to activate this clicking sound. Anyone have any clues to my problems? Thanks.
trying to remove it. I thought better to let it be than force something. I am going to do a bit of looking on the net to se what i can find regarding removal of the panel. Any clues?
