Help! Heat in coupe is always on!!
My 124 from 1988 diesel 250, gives me no possibilities to turn off the coupe heating once turned on. This started 1 month ago. When i start the car and the adjusting wheels (picture 1) http://bildr.no/thumb/298455.jpeg[/img][/url]
is in off postition, the heater gives no heat. If i set the wheels to 24 degrees or whatever (celsius, i am in Portugal), it gives full heat which is not possible to turn off. If i stop the motor and starts it again with the temperaturewheels on zero, it gives no heat...good...but turn the wheels, and full heat again??
I have cleaned and inspected the pump in picture 2:
http://bildr.no/thumb/298458.jpeg[/img][/url]
and the valves in picture 3:
http://bildr.no/thumb/298459.jpeg[/img][/url]
...can anyone help
sincerly terje
...can anyone help
sincerly terje
SOLVED!
Found out myself. Circulationpump was stuck. Took it out and cleaned and put som oil in the holes in the pumphouse.
conclution: if circulationpump is stuck, the heater inside the car goes bananas.
terje
terje
