Turn Key Nothing?
Old Jan 16, 2003 | 12:55 AM
johnk's Avatar
Angry Turn Key Nothing?
i have an '86 300E that makes a clicking sound when starting it.
it's been doing it for atleast a year and now i'm experiencing an intermittant key-key-nothing situation. the local benz shop replaced the starter and it still wouldn't start. any thoughts or gut instincts would be greatly appreciated!
Old Jan 16, 2003 | 06:04 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
I would also have the starter checked. But if it is not starting at all after replacing the starter, try to get your money back. Before swapping the starter they should have checked it. Maybe its only the ignition switch which does not "tell" the starter to do what it is supposed to do. But this would be the first check of a professional whether the starter gets "juice" when the key is turned.
The clicking noise may not necessarily be caused by the starter (it can), since there are so many relays switching when the key gets turned, and it's hard to tell from where the noise may come.
Old Jan 17, 2003 | 02:01 AM
SLV300E's Avatar
300E
if the car does not always start in the P posotion...
try putting it in neutral.... my car has a bad "safety park switch" so i usually have to put it in neutral b4 i start. If thats teh case not a big problem just a matter of not being lazy..
Old Jan 17, 2003 | 05:44 AM
Daniel_uk's Avatar
MB E280
LOL!!
Remember the hand brake then!
You don't have any alarm on the car, eg immobiliser that can play games?
Love the uk. Daniel
Old Jan 17, 2003 | 07:48 PM
SLV300E's Avatar
300E
After my run-ins with an immobilizer id rather get my car jacked then go through wat i did on vacation.
Old Jan 18, 2003 | 07:27 PM
pkmaven's Avatar
Mercedes-Benz 300D TURBO 1987
starter problems
If your battery is in good shape(younger than four years old), and nothing happens when you turn the key, the odds are excellent that you need to replace your starter! If you have a 124 that is over ten years old, be thankfull that this little motor has lasted so long. P.
Old Jan 28, 2003 | 05:21 PM
pifcat2's Avatar
300TE / 300E / 300CE
Tranny starts in N, not P
My '86 doesn't start in P anymore so I need to put it in Neutal like SLV300E,
Does anyone else have this problem and know how to fix this?
My car has nearly 300k and still runs strong. I just replaced the valve guide seals (fairly simple) and now there is very little oil consumption.
Old Jan 28, 2003 | 06:36 PM
MB4JH's Avatar
86 300e
Just need to replace the neutral safety switch!
It is not too hard. You just have to get under the vehicle next to the transmission. If you are not mechanically inclined, leave for the pros...otherwise, go for it!
