Rich fuel smell...02 sensor problem?
Old Jan 3, 2009 | 04:50 AM
luvmuzik66's Avatar
1989 300E
I;m smelling a rich mixture from my exhaust, can this be caused by a bad 02 sensor? What are the other causes? I've recently replaced all the valve stem seals to cure the white smoke. I need help because I need to get this car smogged. Thanks in advance. And I get black smoke evrytime I ounch the throttle, parked or on the freeway.
Old Jan 4, 2009 | 04:41 PM
Chinny4290's Avatar
1994 C124 E320 Coupe - 1975 W116 280S
Curious about the fuel smell.
Black smoke means that you are burning oil. How many miles?
Old Jan 4, 2009 | 04:50 PM
luvmuzik66's Avatar
1989 300E
I have 182000...but I think the white smoke is due to burning oil, and black smoke is a rich fuel mixture. I've already fixed the white smoke part by replacing the stem seals. And also, I want to know if the fuel distributor can also cause the fuel mixture problem.
Old Jan 5, 2009 | 03:24 AM
Chinny4290's Avatar
White smoke of any kind means that it's a coolant issue. It's interesting that the white smoke was fixed from the valve stem seals.
Think of it this way. When you cause water to vaporize (the 50% of whats in coolant) it turns into steam, which is white.
When you cause oil to vaporize...or in the most direct way of saying it, burning oil, it becomes a bluish/black smoke.
However, as I just researched gray to black smoke can indicate a too rich air/fuel mixture which is from a wrongly adjusted engine, an extremely dirty air filter, or bad/clogged fuel injectors.
I don't know about the distributor though since nearly all the cars I've driven/worked on used coil-over ignition and is all ECU managed.
I'm still learning with my carbureted 280S. Maybe someone else can chip in.
Old Jan 5, 2009 | 10:34 AM
luvmuzik66's Avatar
1989 300E
There are two things that can cause white smoke, oil and water. The valve seals were hard already when I took them out. They were barely grabbing the valve stem. They were so lose, the valve(s) were doing a free fall. A bluish black mixture base on my experience is a little rich mixture and bluish being normal. It only smoked in the morning start up and on acceleration. Like I mentioned, that has been fixed. Is there anyone out there to give a comment on this thread regarding the 02 sensor issue and the fuel distributor? What else can cause a ricj fuel mixture.
And if my injectors are clogged, there is no possibility for a rich mixture. It should be leaning out. My 2 cents.
Old Jan 5, 2009 | 04:37 PM
Chinny4290's Avatar
Learn something new everyday
