722.6 5 speed conversion
The tuning aspect is very difficult and I can make shift very smooth but there is always some circumstance which you will get a harsh shift. Mainly on the light throttle slow speeds. Not much different than Mercedes on this. They were updating the shift programs until they discontinued the transmission.
do you have any pics? diagrams?
how hard was the swap?
what was the cost like?
and finally...WOW....i really need more information....
Cost is not to bad. The transmissions cost between 12-1500 at salvage yards. The trans I used is out of a c230. The bellhousings are different for different engines but basically it will bolt up to any m102, m103, m104, m119, m120, m606, m603, m602, m601, and I have been told that the m117, m116. The shifter is from a c-class. Others will bolt in but do not fit the shift wood. The shifters cost about 450 at the salvage yard. The tcu is about $1150.00 with a tune installed that will operate the transmission. The tune is currently set up to be more firm than it can be because of not having the speed sensors operational. Also because without the car in question to tune with it cannot be exact. It cannot be tuned on a dyno either. It is all road time.
The reason for not doing a manual. Is primarily I do not want a manual. I can have all the benifits of a manual with this setup and faster shifts. Mercedes has never made a decent manual transmission. Also availability is not to great. Pretty much you do have to import them from Europe. Otherwise find the one or two 300e that came to the U.S. with them or a 190. They have the worse shifters I have ever seen in any car. I can have a paddle shifter and my shifts take about .02 seconds to complete.
Huuumm This is very interesing.
I live in europe an I have a 5 speed manual transmission on my 300E. Well my clutch is about due and I was thinking about putting in a 6 speed manual transmision from a W210. This type of transmision was optional on the early W210 over here. What do you guys think? Will it fit? Is there a place were I can find some info for such transformation?
I drove one of these W210, a E200 CDI 6 speed manual, and wow it was very nice to drive. Very smooth and powerfull.
If someone can help I would apreciate it alot.
Are you still in business to make e320 cdi 722.6 conversion to manual?
Seriously interested.
Thanks,
Peter
