Auto dimming mirror
This mirror has the homelink controls which allow me to turn on my outdoor flood lights and living room lamps as I pull up to the house. It also has ambient lighting which is nice.
so that black thing stuck on the back of the mirror with the wire is part of the homelink setup, or a sensor for the autodimming?
The only thing I had to do to the w210 mirror was to remove it from its original mount, very easy the ball popped right out. Then I cut the w210 ball off the mount with a dremel, took about two minutes. Then I removed the ball off the w124 mount, no cutting it just unscrews. Next pull back the black rubber coating on the 124 mount to expose the medal. Since the 124 mirror's ball attaches in the back and the 210 mirror mounts from the top you need to cut off the bottom curve of the 124 mount with a dremel or saw. Most of the w124 mount has a path to run the wires you just need to drill a small hole in the bottom part of the mount so that wires can make it into the new mirror. Next mount the 210 ball that you cut off onto the 124 mount, I used putty epoxy, it was set in 20 minutes. Finely pull the black rubber coating down pop the ball on the mirror and wire it up. The large hole in the top of the 210 mirror is factory, the stock ball is attached to a large shaft that the wires ran through.
It may seem like a lot of steps but altogether it took about an hour and it looks like it came from the factory.
The black thing is actually attached to the windshield and is the rain sensor for the windshield wiper. It looks like it is part of the mirror in those pics, but its not. The homelink and auto dimming sensors are all self contained in the mirror.
Here are some pics that show it more clearly.
Oh and the Mirror is FULL Power....Have to run a harness for the speaker and the mirror then a Mirror control switch....Then to wire it to the memory switch on the drivers door...NO More Mirror adjustment
Not all W124 mirrors have ***** that unscrew, found this out by disecting several mirrors (and none of the W201's have removable *****).
That said, this is not a simple procedure, plus your range of motion is limited without cutting much of the rear cover on the auto dimming mirror.
The main issue is that the W124 stalk is curved at the end and designed to mount to the back of the mirror, where as the auto dimming mirror has a straight stalk and mounts from the top, so you have to enlarge this opening to accomadate the curved W124 stalk.
Obivously, this can be done, as Vanwiek has shown, but I wasn't happy with the looks or limited range of adjustment, so I scraped mine. I found the gap left over by the factory auto dimming mirror mount was perfect to add the center sun visor to, so it looks much better.
I didn't even open the case of the new mirror.
I found this project to be one of the most simple modifications I've made to the car.
2phast, Does your center sun visor rest flush against the headliner or does it rest against the dome lamp? You site doesn't show a zoomed out photo of the finished project.
Here are some photos that show the greater range of motion that this setup afford you.
My center sun visor sits flush against the headliner, its pressure it into the gap left by the mirror. Had to modify the sunvisor a little to get it to sit flush against the headliner though.
