Is a spring compressor needed for w124
Old Jan 29, 2009 | 01:51 PM
GEDaggett's Avatar
1994 E320 (current)
Do you need a spring compressor to replace the springs (front) on the E320. I need to swap the springs out and I want to just do it in the garage if I can. I am also going to replace all the rubber on the suspension.
Old Jan 29, 2009 | 02:01 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
If it is similar to a w126, which I think it is, than yes.
Old Jan 29, 2009 | 02:04 PM
CDP's Avatar
CDP
W124's
Yes.
Old Jan 29, 2009 | 02:51 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Eh, not necessarily. You can put the car on jack-stands, get a piece of wood on a floor-jack and bring it up under the control arm. Unbolt the control arm and lower the jack. Just make sure the jack is as centered as possible. Then simply reverse the process to replace. It's actually very easy. I did it with the help of a friend when I replaced my springs.
Old Jan 29, 2009 | 03:04 PM
YNVDIZW124's Avatar
lots of cars
If you don't want to have a 50-50 chance of popping a spring in your face and killing you, i would use a spring compressor.
Old Jan 29, 2009 | 03:09 PM
A little dramatic. Ive actually had closer calls with a spring compressor than my method. Problems with them not threading up or seating correctly are common. At least with the jack, when I release the pressure, it's controlled, and Im 10 ft. away.
Youre right though, it is dangerous, but if youre cautious and use common sense just as you would if you HAD a compressor, you won't have any problems.
Old Jan 29, 2009 | 03:59 PM
TMAllison's Avatar
09' E320
Most shops would use a Klann spring compressor.
Old Jan 29, 2009 | 04:29 PM
childofjuly's Avatar
1995 E 420
i bet u're the kind of guy that uses a butter knife as a screw driver sometimes! (not a bad thing, i do it too) but still buy a spring compressor!
ZorroAMG's Avatar
Enzo, my Benzo
If you're strong like Zedstyle, you can just squeeze 'em by hand.
Old Jan 29, 2009 | 04:58 PM
GEDaggett's Avatar
1994 E320 (current)
I think I will use a compressor. They have some with a center retainer so that if it does jump it is limited as to what kind of damage it will do.
Old Jan 29, 2009 | 05:48 PM
Or if you chewed new Trident Plus Recaldent, you could just use your teeth.
Old Jan 29, 2009 | 06:35 PM
STLe320's Avatar
95 e320...sold the rest
LOL literally I just saw that commercial 2 minutes ago!
Old Jan 29, 2009 | 09:37 PM
Federic0W124's Avatar
1992 400E
just remember you can't use the spring compressors that
they rent out at auto parts stores. you'll need the plate style
(klann)compressor.
Old Jan 29, 2009 | 10:17 PM
GEDaggett's Avatar
1994 E320 (current)
(klann)compressor.
Thanks for the heads up.
Old Jan 30, 2009 | 11:11 AM
ZedStyle's Avatar
Youngtimer
i alse remove lugnuts with my fingertips...
you're silly, man, wasn't expecting to read that, made me bust out laughing!
Old Jan 30, 2009 | 12:01 PM
ZorroAMG's Avatar
Enzo, my Benzo
Tis what I do....haha (sorry, off topic but wish me luck, I have an audition for a lead in a new movie today with Rumer willis, bruce and Demi's daughter!!)
Old Jan 30, 2009 | 01:02 PM
pifcat2's Avatar
300TE / 300E / 300CE
The plate and center screw type spring compressors cost about $250 (Klann copy) on eBay or nearly 2x for original Klann brand IIRC. Some members rent them or buy, use them once, and sell them at a discount. Do a search or pose a question, you may find someone local to you who will loan it for free.
Old Jan 30, 2009 | 02:00 PM
Hanno's Avatar
6.9
Less than 5 min with the proper tool. You could remove it without the tool (done it on the 300E parts car with the threaded rods and clip tool, but I wouldn't even attempt getting it back in that way).
Old Jan 30, 2009 | 04:25 PM
YNVDIZW124's Avatar
lots of cars
Yeah, me too. Sorry for being dramatic but i've had some pop out on mustangs using the method you mentioned. I also had a 69 mustang fall on me but it landed on the jack stand and a tire i had underneath. So yeah autozone spring compressors won't work and you must use the right one (plates) for the springs to even move.
Old Jan 30, 2009 | 09:43 PM
190E 16V's Avatar
1987 560SL
Allrightttt!!!!!!
Way to go, Mark!
Hey, how did Wild Roses go? Haven't seen it listed.
Let us know what's up with the feature. Is it to be shot in Vancouver?
"I knew him when he drove a 300E..." LOL
Old Jan 30, 2009 | 10:37 PM
Yeah I figured you had an actual experience where that went wrong, since you seem to be one of the more hands-on members on the forums. I actually thought to myself when you posted that "Hmm, Im surprised he hasnt tried that."
Oh and I don't see Zorro ditching the 300e even if he gets bigger. Except maybe for a 500e, and in that case all the cool mods would go with. Enzo would still be alive
