SL wheels, I think
Old Feb 11, 2009 | 02:38 PM
Island300CE's Avatar
1992 300CE
SL wheels, I think
A friend has a set of what he believes are wheels off a 92 SL. They are 16X8 with a 45 offset. I've looked at the fitment charts. Will these fit my 92 CE or will I need some spacers? If they fit I was looking at running 225 50 16's for tires. Thanks in advance.
Aloha
Old Feb 12, 2009 | 06:26 PM
termite's Avatar
2013 E350 wagon cuprite brown; sold:2014 ML63; R500 Saks Edition; R500; more W124s than I can count
w124's need an et of 34-35 on a 16x8 wheel and should run 225/55-16...so, you need about 10mm of spacer...hth
Old Feb 12, 2009 | 06:47 PM
STLe320's Avatar
95 e320...sold the rest
You don't HAVE to use those specs. I'm running 215/50/16 on 8" wheels, and the offset is 41 all the way around, with absolutely no rubbing/scraping issues.
Check the W124's Running Gear Thread for wheel fitment questions.
Old Feb 17, 2009 | 03:14 AM
1992 300CE
Thanks for the info. I rechecked the wheels. They are 16X8 with a 41mm offset so I think 225/50/16's should fit.
Old Feb 22, 2009 | 04:52 PM
neanderthal's Avatar
There is a wealth of information in the running gear thread and also if you use the search function.
