Replacing front main crank seal M103 engine
Old Feb 14, 2009 | 06:31 PM
Ron in SC's Avatar
99 ML 320, 97 Porsche 993 C2S, 92 300E
Question Replacing front main crank seal M103 engine
When replacing the front main crank seal, on M103 engine, can the hub be removed with the harmonic balancer attached?
My Alldata DIY said to take balancer off and then use a special puller to remove the hub. I do not have the puller I was thinking it would come off without to much prying. I changed harmonic balancer on my ML 320 and it came off pretty easily.
