94+ hoods question.
Old Jan 28, 2003 | 07:56 PM
soldsep's Avatar
87 300 E
94+ hoods question.
Alot of the older 124's are upgrading their hoods on this forum so i got a quesiton. Is it really that simple? Just buy a hood and install? Or (like with most car parts) do i hafta buy other things in order for it to work? I have a 88 300E. and i would like the newer style hood.
thanks in advanced
Paul
Old Jan 28, 2003 | 10:33 PM
suginami's Avatar
93 300E
You'll need a new hood, chrome grill surround, grill insert, and new headlights.
Old Jan 28, 2003 | 11:12 PM
soldsep's Avatar
87 300 E
i have euro headlights will that do?
Old Jan 29, 2003 | 11:48 AM
ZorroAMG's Avatar
Enzo, my Benzo
soldsep,
Yup euro's will do...it's not for fuctionality just look...euros re actually better than the 94-95 headlights we get here in North America..
Old Jan 29, 2003 | 12:13 PM
suginami's Avatar
93 300E
Euro's will do, but they have to be Euro's for a '94 - '95 hood. If you have Euro's for the '86-'93 hood, then they won't fit.
Old Jan 29, 2003 | 01:01 PM
ZorroAMG's Avatar
Enzo, my Benzo
Sugi,
That is not correct... the only function the headlights serve in the facelift are cosmetic. You could probably even leave the two piece headlighs in place with the new hood...it just wouldn't look good
Old Jan 29, 2003 | 01:45 PM
suginami's Avatar
93 300E
Originally posted by ZorroAMG
Sugi,
Euro or U.S., '86-'93 lights and '94-'95 lights are shaped very differently.
The '94-'95 hood will close shut with the old lights, but there will be an ugly gap. The grill portion of the hood is much smaller.
The converse is not true. If you have an old style hood, it will not even close shut with '94-'95 lights.
Old Jan 30, 2003 | 12:30 AM
soldsep's Avatar
87 300 E
ok so i have a one piece euro head lights. Now how do i know if they are 94+ or the older version?
Old Jan 30, 2003 | 03:22 AM
ZorroAMG's Avatar
Enzo, my Benzo
Ok, I may be incorrect on the info about hoods fitting euro or NA spec lights but I do know this... Unless you ordered your lights from a mercedes benz dealer and told them you wanted euro lights from a 1994-1995 E320/420 you have most likely euros from a 1986-1993 300E. As well if you ordered them from an aftermarket dealer and said you needed euros for your 1988 300E, you'd get the same euros. (OEM or not) Long story short, if you asked for 94-95 euros, you may have them, otherwise they are the <94 lights and according to sugi, will not fit the newer hood.
Hope that helps
Old Jan 30, 2003 | 03:41 AM
soldsep's Avatar
87 300 E
I guess i will need to check with my supplier.
Old Jan 30, 2003 | 11:19 AM
suginami's Avatar
93 300E
I agree with Zorro AMG.
Do you have these euro's installed on your car now? If so, then they are definitely 86-93 lights. The 94-95 euro's wouldn't fit because with your current hood, the lights would prevent it from closing.
Old Jan 30, 2003 | 12:01 PM
soldsep's Avatar
87 300 E
ok then i guess they are not the newer version. HOw much of a gap would i have if i did install a new hood wiht my older lights?
Old Jan 30, 2003 | 03:07 PM
suginami's Avatar
93 300E
You'd have a several inches gap.
I guess 2 to 3 inches on each side. I've seen a picture posted before on this site or another one that shows what I'm talking about.
I'll try and find it.
Old Jan 31, 2003 | 02:12 AM
soldsep's Avatar
87 300 E
i guess when i get the hood i can sell my current headlights and buy new ones.
thanks for the info
Old Feb 3, 2003 | 02:25 PM
M104-AMG's Avatar
W124 E36T AMG; W124 500E
If you have the early Euro "flat-face" headlamps, you can order the 94-95 Euro lenses from Paul at Puma (http://www.puma-access.com). They will snap in place.
:-) neil
1988 360TE AMG (with facelifted hood & E500 headlights!)
1993 500E
Old Feb 3, 2003 | 02:35 PM
soldsep's Avatar
87 300 E
i might check that out. thanks.
