Camber Adjusters?
Old May 10, 2009 | 04:22 PM
battlecat714's Avatar
a TVR Cerbera Speed Twelve
Originally Posted by omegabenz6
Jorge, what about the RDMTEK rear camber kit. It works by pulling the lower control arm in, bringing the bottom of the tire in, whereas the other "camber arms" push the top of the tire out, closer to the fender. Kmac are rumored to make a squeaking noise by some of the users.
www.rdmtek.com
Rear Suspension Components: Standard and Shortened Lower Control Arms to
reduce Camber and Adjust Rear Toe, for W124, W201, W202, W203, W208, W209,
W210, R129, and R170 CHASSIS
I've got the RDMTEK front and rear camber kits/camber plates on my 500E, I got my alignment nearly perfect (-1degree at all four corners, with H&R springs).
Austin,
I want to try out the KMAC kit first then if I still don't like it, I'll check yours out or maybe Len's too as he has some available for these cars.
I bought the KMAC kit last Friday so it should be here next week...we'll see after the install
Old May 12, 2009 | 02:05 AM
CharlestonN's Avatar
03' CL55 AMG
Originally Posted by battlecat714
Austin,
Where did you buy the kit? i tried this place K1 Motorsports and when i call it just rings and rings
Old May 12, 2009 | 12:30 PM
ZedStyle's Avatar
Youngtimer
isn't there some rule where you have to be a sponsor before you can sell products on here??
Old May 12, 2009 | 01:12 PM
CDP's Avatar
CDP
W124's
Guys, I know of someone who is selling the KMAC kit if anyone is interested - It's just sitting around collecting dust.
Old May 12, 2009 | 01:14 PM
CDP's Avatar
CDP
W124's
By the way - Lenard's Camber arms are TOP NOTCH! I can vouch for that guy - He knows what he's doing.
Old May 12, 2009 | 07:33 PM
LOL. He isn't banned yet so I guess its ok.
Old May 16, 2009 | 03:31 AM
  #32
03' CL55 AMG
The K-Mac kit is weld on right? how hard is it to "undo" the addition of the K-Mac camber kit if it makes too much noise after install?
Old May 17, 2009 | 07:18 AM
  #33
ksing44's Avatar
2010 VW Golf TDI
There is no welding. See the picture for a W124 that installed both camber and toe bushings from K-MAC. The K-MAC bushings use an eccentric bolt embedded in a red polyurethane bushing for both the camber and toe. My 1995 E320 already had the same eccentric type of thing for toe adjustment that was stock from Mercedes, which to me seemed a perfect validation of the concept. I only installed the lower control arm bushings. Actually, I paid someone else to install the bushings and they said the hardest thing was getting the old bushings out.
You can buy the bushing directly from K-MAC.
http://www.k-mac.com.au/
Old Sep 16, 2009 | 11:34 PM
  #34
BenzBro's Avatar
1990 300CE, 1984 190e 2.3 (sold)
What is everyone on here using to adjust their camber issues?
KMAC?
RDMTEK?
Nothing?
Old Oct 3, 2009 | 07:16 PM
  #35
John M.'s Avatar
1991 300E
I am using SPC Performance rear camber bushings (just released 4-5mo ago). I have put nearly 13,000 miles on them with no issues so far. They are HD rubber as opposed to the K-Mac kit which is red urethane. With Eibach Springs and Bilstein Sports, my car rides very nicely. It brought the negative camber in the rear from -3.5 to -1.2~.
If you are interested in the SPC bushings, PM ME, I can get them....they are nearly half as much as the K-MAC kit too .
Old Oct 4, 2009 | 02:27 PM
  #36
BenzBro's Avatar
I just bought the KMAC kit the other day for $289 online. I'll try to post pictures on the install and the results before and after once I get them on.
Old Oct 5, 2009 | 01:07 PM
  #37
joef's Avatar
S500
I've got Kmac on my cabrio. They're alright, at the time that was all that was available and I paid an arm and a leg for them direct for Australia.
When I do it again I will got with RMDTEK components. For the rear control arms there are less moving parts than the Kmac kit. A member from 500Ect said he heard creaking with the Kmac kit coming from his rear, switch to the RDMTEK control arms and it was gone.
Old Oct 5, 2009 | 04:01 PM
  #38
appatula's Avatar
95' AMG SeeThreeSix
I just got the benzboy arms in. Negative camber was MEAN with the stagged mono II's and intraxs in but tire wear was also mean. Just got a appointment at a specialty shop as no one will touch a lowered Mercedes around here. So far (with camber adjustments by eye) they solve the problem. However now that my allready wide rears are stuck out another .5-1" my fenders are going to need some attention big time.
