Srs Light Problem
Old Feb 12, 2003 | 07:15 AM
SPIKES's Avatar
2019 S63 COUPE
Srs Light Problem
hi
my srs light has come on. how do i check the "clock spring".
how do i reset this light?
am i looking in the right place for the problem?
thanks
Old Feb 13, 2003 | 07:09 PM
SPIKES's Avatar
2019 S63 COUPE
HELP
ANY SUGGESTIONS PLEASE?
Old Feb 14, 2003 | 04:44 PM
MB4JH's Avatar
86 300e
What year is your car?
Any other symptoms? It could be sensors, battery low, alternator problems, OVP going bad, etc, etc.
Old Feb 15, 2003 | 08:49 AM
SPIKES's Avatar
2019 S63 COUPE
it is a 1994 e 320.
it has a new ovp from a check engine light problem about a month ago.
no other symptons other than clicking noise when i turn the steering.
that is why i assume the clock spring.
how do i check it?
THANKS FOR YOUR REPLY.
Old Feb 17, 2003 | 01:03 PM
MB4JH's Avatar
86 300e
HAs anybody work on your recently?
There are some "contact rings" behind your steering wheel that sometimes get dirty with carbon. That may be causing your problem. The only way to check it, as far as I know, is to remove the steering wheel and see. Did somebody pull the code(s) for the check engine light?
Old Feb 17, 2003 | 07:09 PM
SPIKES's Avatar
2019 S63 COUPE
all sorted
it was the clock spring "fixed" it and the lihgt goes out now. i noticed as well that the horn was not working.....should have been clue that power not comoing to steering and airbag...
thanks for your help.
