Interior Lights
Thanks,
James
Yeah i have tried that knob (rehostat..sp?).. thats what i was referring to when i talked about the dimmer switch.. but is it normal for neither the dash nor the console lights to not work together? are they all connected?
Thanks,
James
The console lights are powered by a grey wire with a blue stripe. They all meet at a junction box behind the ashtray. There are about six of these grey/blue wires. There will be one that brings the juice into that junction box. Check for a short there.
I had these problems on my 88 300E, I hope this helps you.
the shemdogg
Another possibility could be that you have a short. Unfortunately, depending when your car was built in '86, you may or may not, have a red fuse (looks like a lught bulb but, it is red) behind the instrument cluster. I think, MB started to install these fuses in early '87. Yes, the instrument cluster has to come out for this one.
Good luck!
Thanks,
James
It was the "Instrument cluster illumination control switch"
Part # 000-542-38-25 Should be about $35-40 for the part and about 1 to 1.5 hours for labor.
1. Check your rheostat (replace or repair if necessary. Repair is easy, just jump the connectors....did this on my mom's car, now her dash is super bright)
2. Check your fuses...both under the hood and behind the dash. (Best to just invest 10 cents and just replace them with new ones)
3. Attach a ground wire to the back of the dash (this solved my problem)
