Hard rain = wiring harness short?
1995 E320 wagon
Barely made it home tonight.My '95 E320 wagon was acting up in the rain again, chugging and misfiring like crazy.
I've had this problem before and thought it could be the spark plug wires/coilpack but I've changed all those only to find out it was the drain holes on the battery side of the raintray being clogged.A MOUSE! had made a nest of cotton jacket lining all inside the raintray and it was pooling water everywhere near the ECU harness.We got the compressor air nozzle and blew the area out and it had been fine for many months but the same symptoms have come back!
It started happening again when I took it to the auto car wash, (I usually wash it by hand), and once more tonight in a torrential rainstorm <<< that is the common denomiator.
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
I had same problem were your pre cats glowing when you looked under hood. Your sucking up water. You need all your intake stuff on and the plastic peice on bottom of car.when mine was off it was horrible in the rain.
1 Post
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
Has your wiring harness ever been replaced? The original 94-95 engine wiring harnesses have 100% failure rate. The wiring insullation turns into dust after about 10-12 years.
1995 E320 wagon
Wiring harness was changed by the previous owner, ( the jacketing is 'glossy').
We took the battery/tray out and blew the area with the air pressure nozzle while vaccuming and it seems to have worked
I have driven in 2 or 3 rainstorms since that and it's held up fine.
My wipers go on by themselves sometimes and the blinkers won't always work but I suspect that I need a new stalk, (sensor).
