I got CEl, and god the codes. Need help.
Old Aug 28, 2009 | 03:56 PM
gorillajin's Avatar
1994 e320 sedan
I got CEl, and got the codes. Need help.
Ok, I built the radio shack code reader.
I tested pin#3,6,8, and 14. I got bunch of codes. I need little help here.
So pin#3 code is 2, which is O2 sensor, I ordered the part.
Pin#6, I got 2, SRS control unit self test failure
8, Voltage supply interrupted
9, SRS warning lamp (with flashing SRS warning lamp impulse counter scan tool button held too little time to read out the DTC memory or too long to erase DTC codes. Reread codes)
Pin#14, I got 5, Stop lamp switch
11, Closed throttle recognition signal to engine control module (HFM-SFI or left LH-SFI) Fuel safety shut-off to engine control module(HFM-SFI or left or right LH-SFI)
Please give me some advices.
I posted the same thread to other MB forum.
Old Aug 28, 2009 | 07:35 PM
gorillajin's Avatar
1994 e320 sedan
Can anyone give me how to check air bag? I got information that somebody tried to disconec the air bag cable without disconnect the battery so it throws the code.
What is stop lamp switch? Anyone?
Old Aug 29, 2009 | 06:46 PM
epowers777's Avatar
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
try this not sure if itll work
Click Me
Old Aug 29, 2009 | 07:00 PM
gorillajin's Avatar
1994 e320 sedan
Click Me
Um...I am sorry, but what is vin decoder has anything to do with the check engine light codes?
I have checked it when I got my car first time. It has additional 3rd stop lamp (с 01.10.1989)..but I just don't know where stop lamp switch is...
If you gave me the link to check whether I have air bag or not, it has air bags, and I just wanted to know how to check whether air bag cable is connected or not.
Sorry about my English, it's my 3rd language.
Thanks.
Old Aug 29, 2009 | 07:07 PM
epowers777's Avatar
click on the vin open it right next to vin click codes maybe it reads codes to just trying to help
Old Aug 29, 2009 | 07:16 PM
epowers777's Avatar
I see your having trouble with smog why dont u post a seperate link need help pass smog? Have you dont a complete tune up? o2 sensor ? ovp relay? pm me with ??maybe i can help you
Old Aug 29, 2009 | 10:16 PM
gorillajin's Avatar
1994 e320 sedan
I got code 2, whcich is O2 sensor. I ordered it and it will be arrived on Monday. I reset the code for now. The reason I fialed the smog was, the PO took out the check engine light bulb and brake warning light bulb. So when I took the car to a station, a smog tech told me that I failed because the check engine light isn't functioning.
I put the new bulbs, read the codes, and I got those codes.
I reset the codes and no more check engine light.
After I replace the O2 sensor, I will take my car to the smog station and test it again.
I passed everything when I did the smog, exept the check engine light.
I changed spark plugs&wires, and valve cover gasket. Tensioning shock absorber, upper guide pully, and the belt. OVP and O2 sensor haven't been changed.
Thank you.
