heater failure?
Does anyone have an idea what is faulty.Thanks.
Well, you can check the electrovalves switches that open/close the water flow to cabin. They are 2 if your cars has climate control or 1 if it has automatic air conditioning. They are located beside battery and front right strut.
Then you can check the electrical water pump. Use to be located near electrovalves, but this depends on model. The shape and form is similar to electrovalves but it is more large.
