1990 300 TE 4 MATIC No Reverse
Old Oct 7, 2009 | 11:06 PM
HalJester's Avatar
1990 TE 4 MATIC
166000 mil Works in drive and shifts good, but R is like Neutral. The fluid looked good no bits in the bottom. I think a valve in the valve body is stuck. I wood like to know .
Thank you for info.
H J
Old Oct 20, 2009 | 10:24 AM
Chappy's Avatar
AMG
Has the car ever been damaged in an accident?
Old Oct 20, 2009 | 11:26 PM
HalJester's Avatar
1990 TE 4 MATIC
No the car has not had an accident. It went in reverse 3 times Sunday only when the trans was cold but slow it tuck 15 to 25 sec to grab but it did not slip strong pull.
Thank you for the response.
Old Oct 21, 2009 | 12:57 AM
latief's Avatar
1993 300e 2.8 - M104 Engine, SOLD; S320 2000
That is the famous no reverse situation....
transmission needs some significant work, do a search on it there is plenty of information!
good luck,
Old Oct 21, 2009 | 07:09 AM
Chappy's Avatar
AMG
I had the same issue. It required a partial re-build of the tranny.
Old Oct 21, 2009 | 09:05 PM
HalJester's Avatar
1990 TE 4 MATIC
I have searched and not found the info I need on transmission tare down and rebuild .
My time on line is limited Thank You for your help
Old Oct 21, 2009 | 09:08 PM
latief's Avatar
here is where the techs hang out....
http://www.peachparts.com/shopforum/...isplay.php?f=1
search under "no reverse"...unfortunately, their is no easy fix for this
good luck
