300TE tailgate damper replacement
rear. If you push on the inside of the next headliner-rod, it will
bow downwards. That will give you enough clearance to remove
the shocks in forward direction. The forward bolts of the shocks
have a square at the end and are secured by a metal hook,these
need to be bent back. Have someone hold the Tailgate to relieve
tension to get these out. Open the hatch as far as possible and
secure with a propstick, this will make it easier to remove the
C-clips for the rear bolts. Reverse installation.
The OEM replacement shocks I've got are actually made by Bilstein. Hey, does this mean I can go round telling people I've put Bilstein shocks on my 300TE?
