New shifter Problem Hlp plz.
87 300 E
So i got the new shifter shaft so i can update my shift knob. Problem is after i installed it it doesnt really go with the grooves of the plate (thing that says P R N D 3 2) So sometimes when im in drive i hit a bump and it will shift me to 3 anyone else got this problem?
W124
You can adjust it from under the car. Prise off the metal clip, slacken the locknut, twist the end of the selector rod then tighten the locknut and re-fit the clip. You'll need to do it over a pit or on a ramp.
It'll make sense if you look underneath. I hope!
