Suspension/tie rod question...
Oh, and one more note. Something I didn't even notice. On the driver side I had vented disc brakes, on the passenger side I did not. So it appears someone changed the rotor on the passenger side before, but due to this bolt issue didn't change the driver side.
So I have that going for me.
Now to order the other side so I have a matched set (knew I wasn't doing them both the same weekend due to time, and wasn't sure I could complete it myself having never used the spring compressor before).
All in all it went ok... and the car is back on the road... control arms look like they could be done, if I do them one at a time (lower one time then upper)... something to consider for later. Thanks all for the suggestions and help!
So I've seen the heavy duty compressors at the parts store for rent or purchase, so I go rent one. I figure I can just recompress with that and put it all together then take it back.
Now I'm 7 hours in, have it all together, the heavy duty compressor having shrunk it enough to get it on, but now I can't get the heavy duty compressor off.
I've tried using the smaller compressor rods to shrink the spring to get it out, no go. I've tried a hammer, no go. I gave up.
Have slept since... and now am at work, so when I get home I get to try again. The only thing I can think of is to take it all back apart, remove the heavy duty compressor and try again. This is a nightmare.
This morning, took it to work... and now I have a rattle every time the wheel extends (which tells me the top bracket is hitting the top of the strut mount... ). So tonight I get to tear it all apart again and see if I can figure out what is wrong. The top bracket on the other side sits about 1/8 to 1/4 inch above the rubber housing piece and doesn't rattle, so I don't have any idea what is wrong.
This has been an exhausting exercise, and if I cannot find it, I will likely have to take it to the dealer and have them replace the strut and repair whatever is wrong. So... if no luck tonight, I'm looking at about $1400 US for two new struts to be installed.
