Blown Head Gasket allowed oil to corrupt cooling system
Old 06-08-2010, 07:35 PM
  #176
wagmar's Avatar
1991 300e, 1989 300e
The in-tank filter is in the fuel tank.
Old 06-08-2010, 07:44 PM
  #177
wagmar's Avatar
Its connected to the fuel supply line at the bottom of the tank. Here is the illustration:
http://www.ps2cho.net/downloads/MB%2...03/47-4100.pdf
Old 06-08-2010, 07:53 PM
  #178
loclark757's Avatar
1988 300E, 1994 E320, 1999 ML 320, 2002 SLK 32 AMG -SOLD-, ML 350SE -REPOSSESED-
Old 06-13-2010, 07:19 PM
  #179
loclark757's Avatar
How do you remove the fuel feed line from the In-Tank Strainer...
It looks like the hose goes into some type of a metal sleeve?
Old 06-13-2010, 08:03 PM
  #180
wagmar's Avatar
I believe it is threaded into the piece. I cannot say for sure, as I have never removed one. Logic tells me it may be threaded into the strainer.
Old 06-13-2010, 08:09 PM
  #181
loclark757's Avatar
Im guessing some vise grips would work...
It doesn't say anything about a special tool for it in the FSM...
Old 06-13-2010, 09:04 PM
  #182
wagmar's Avatar
I have not seen a specific tool for the fuel line removal in the Samstag catalogue. A crimping tool is featured in their catalogue that crimps the fuel line closed when changing the filter, but I use a mini-visegrip for that operation.
Old 06-15-2010, 06:58 PM
  #183
loclark757's Avatar
Ok Im going to need to remove the fuel tank to get that line out (fuel feed line from strainer). Its hard to get at and I cut the hose off so I could get it out but no luck at all.
What could I use as an improvised tool in order to get the two rivets out of the guide funnel where you put the gas in...
Can this tool be bought at any auto parts stores...
Old 06-15-2010, 07:37 PM
  #184
wagmar's Avatar
You may need to purchase the tool from the dealer. The part # can be found at:
Old 06-15-2010, 07:40 PM
  #185
wagmar's Avatar
Tank removal should not be that difficult. I saw a guy pull one at the salvage yard, and I believe it took him about 45 min.
Old 06-15-2010, 07:42 PM
  #186
wagmar's Avatar
The book says you can remove the fuel strainer with tank in place. You ought to try that first.
Old 06-15-2010, 07:44 PM
  #187
wagmar's Avatar
Loosen the locking nut with a large socket.
Old 06-16-2010, 06:07 AM
  #188
loclark757's Avatar
Are you referring to the nut on the fuel feed line or the base of the strainer?
Old 06-16-2010, 09:57 AM
  #189
wagmar's Avatar
From the way it appears, the large nut at the base may be integrated into the strainer. It may be one threaded piece.
Old 06-16-2010, 07:00 PM
  #190
loclark757's Avatar
Nope the fuel feed line hose screws into the strainer. Can't get it loose! I even cut the line up to where the metal sleeve screws into the strainer. It's in there tight...
A Mercedes dealership will not sell tools to anyone!
Old 06-16-2010, 08:20 PM
  #191
loclark757's Avatar
Would it be ok to use a grinder to grind it off half way. Or would that create a fire with it being so close to the gas tank...
Old 06-16-2010, 10:15 PM
  #192
wagmar's Avatar
The strainer, I believe, is threaded into the tank. How else would it be secured? The hose would thread into the base of the strainer, I can understand that.
Don't use any grinder. You want a total absence of spark. I'll be at the salvage yard tomorrow, and take a look at one.
Old 06-17-2010, 12:34 PM
  #193
wagmar's Avatar
Back from the salvage yard today. Pull the weather boot away from the tank. It is a rubber cover about 3" in diameter. Since you have cut the old fuel line off, now you should be able to get a deep socket around the fuel line nut. Remove the old line. Now you should be able to get what looks like a 22 or 24 mm socket around the base of the strainer. Turn counter clockwise, that should do it.
Old 06-26-2010, 07:35 PM
  #194
loclark757's Avatar
Nope the base of the strainer is 46mm exact thats what the Mercedes tool is.
The one at baumtools and samstag is part # M0035A $$$$
The feed line came out with the use of a 19mm combination wrench.
Any way I could find a 46mm socket locally?
Old 06-26-2010, 10:49 PM
  #195
wagmar's Avatar
46 mm wrench substitute
Try using a "channel lock" pliers on the widest setting. If that does not work, you might get a large socket from a Snap-On tool dealer.
Old 06-27-2010, 09:53 PM
  #196
wagmar's Avatar
The gas gauge sending unit is secured by the large nut (46mm). The strainer nut looks like its a 22mm or so. Double check to be sure.
Old 06-27-2010, 10:07 PM
  #197
loclark757's Avatar
Your right. But your referring to the factory hose nut which was 19mm. The new aftermarket one has a much larger nut 22mm. If you change the hose you have to change the strainer as well. This I did not know.
Im gonna get a 46mm impact socket 1/2 drive off the internet and see what it does...
Old 06-28-2010, 04:35 PM
  #198
wagmar's Avatar
Sounds like you are on the right track.
Old 07-29-2010, 06:55 PM
  #199
loclark757's Avatar
Ok I got everything worked out. Bought the 46mm socket from Baum tools in Florida. I replaced every hose on the fuel system.
Im going to put it all together this weekend!
Keeping my fingers crossed that it all works...
I have a spare fuel pump that I can use if need be...
Old 07-29-2010, 08:03 PM
  #200
wagmar's Avatar
When everything is together, you need to prime the system. You do that by turning the key to the "on" position. Do that several times to pressurize the system. Then turn the key to start & hold it for 5-10 seconds until it fires.
Quick Reply: Blown Head Gasket allowed oil to corrupt cooling system
