Procedure for Cab Hydraulic Cylinder Removal?
Old Jul 30, 2010 | 12:13 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Baldazep, when one of my main cylinders (behind the rear armrests) leaked, the puddle was under the front fender behind the front wheel, just like you described.
Old Aug 1, 2010 | 08:09 PM
baldazep's Avatar
1995 e320 cabriolet,2004 BMW 540it,1997 BMW 740i
Thanks for the advice but I think I found the "answer"...what was leaking was actually leftover fluid from the original leak.It had accumued in the low spot and just kept seeping out. So I got this crazy idea to pour a small amount of mineral spirits down into the bottom of the inner wheel well....to disolve & "flush out" any leftover fluid. All I know is that a bunch of stuff came out, then stopped......its been totally dry for more trhan a day now. So.....? Think I will now button it all up, & wait for cooler weather before doing the passenger side main cylinder. A new project coming up too: I think I need to replace the fuel pump. Its making a low level sound....like a hum. Ever done one of those?
Thanks to all!
Old Jul 21, 2011 | 11:31 AM
Timroperco's Avatar
1994 e320 Cabriolet
I already posted the following in the Benzworld forum ... but in the interest of those who are searching for tips on e320 Cabriolet top piston (cylinder) and bow piston removal, I'm re-posting it here.
My top failed late last summer as I attempted to put it down. The top had properly unlocked from the tonneau, but the back end of the roof wouldn't lift up more than a half-inch. Knowing this could be a big problem, I quit trying immediately. Next morning, I noticed hydraulic fluid in front of my passenger-side rear tire which confirmed I had a leak somewhere. I left the top up and in locked position all winter, then started gathering information on how to fix this myself.
I'm very grateful to Vexed, Kestas and KBelov and many others for the variety of posts (some going back several years) they have made in this forum. Reading their insights was an enormous help to me. For anyone else attempting this job, I have a few enhancements add to their previous comments. This post focuses mainly on the removal of the main top lift pistons (the long ones that lift and retract the top) and the shorter bow pistons (the ones that hike up the rear of the soft top, just before the tonneau cover for the storage compartment opens.)
1. Getting Started
Before I began, I ordered a couple of liters of the proper Febi hydraulic fluid from GermanAutoParts.com fluid since I knew I'd need it eventually. They charge only $10.96 per liter. Opening the trunk, I removed the fabric and metal cover on the right side that protects the top pump, then filled the reservoir with fluid (it was only about 1/3 full).
I then released the top catches on the windshield, started the car, put all four windows down, and hit the red top lift button. Alas, my hopes that Santa Claus had snuck in and quietly fixed the problem over the winter were dashed. As before, the rear of the top released from the catch but would not lift. And in checking the small plastic bowl I'd placed under the car in front of the rear tire, I saw fluid was again leaking. Trouble was, once I stopped trying to lift the top, the rear of the top reseated itself in the latch and locked ...which meant I couldn't manually lift it. So I tried the red button again, this time with a 1 x 4" board ready to slide in under the top base once it freed itself from the latch. It lifted as before, about an inch, and I quickly slid the board in to keep it from settling down and re-locking.
I shut off the car and lifted the rear of the top upward. I had a 4-foot bungie cord ready, and hooked that into the rear latch piece; I stretched the bungie over the roof and connected the other end to the front latch piece. Voila! Without using a bale of paper towels, I had a simple solution to keep the top propped open at both ends. Next, using the 10 mm wrench provided in the Mercedes tool kit, I manually unlocked the tonneau cover and raised it. Using another shorter bungie cord, I hooked the cord to the tonneau cover latch and then hooked the other end to the upraised trunk latch to keep both open.
2. Interior Removal
It's an unfortunate part of the design, but you need to remove the back seat and interior panels simply to get at the one 40T Torx pin holding the main top lift piston in place. Removing the rear interior is fairly simple and straightforward. Begin by moving the front seats all the way forward, and tilt the seatbacks forward to give you work space.
Rear Seat: Press the red tabs below the front of the rear seat to release the seat, then lift up and out. You may have a bit of a problem negotiating the place where the seatbelt clasps pop up through the holes in the seat, but a few tugs and the seat bottom is out. Next, pull down the center arm rest and move the leather fabric in the notch where the armrest fits. You'll see two shiny hex head screws, 12 mm, up in the right and left corners. Use a 12 mm nut driver to remove these. Then, push or pull up the seat back. This was a bit more of a struggle than I'd anticipated ... but that seat has been there some 17 years. With some tugging left and right, it eventually comes up and out.
Next come the interior side panels. With the seat and seat-back out, remove the several black Phillips screws holding the side panels in position at the base and upper corner. With the widows down, open the doors and remove the shiny chrome door latch plate on the body (three very small Phillips screws that can strip easily). Then, move to the soft-top storage area and remove the Phillips screws that hold down the 3-piece black plastic trim that covers the tonneau latch mechanism (behind the roll-over headrest mechanism) and remove the left and right side portions. After that, you can lift up on the interior side panel and work it loose.
At this point you will want to use a 17 mm socket wrench to release the hex bolts anchoring the seat belts (front and rear) ... plus disconnect the plugged wires for the stereo speaker and the bow piston on the passenger side. Once the seat belts are unbolted, you can back-thread them through their respective holes in the side panel, and now the side panel can be removed and stored out of the way.
Next, there's a black plastic panel covering the side wall of the interior, plus a steel mount for the stereo speaker. The steel mount is held by only one or two screws and comes away easily. But the black plastic panel ... well, it has about 5 or 6 hex-heads holding it in (I simply used a nut driver) but worse, it's been sealed with black sticky gunk for sound deadening. My car seem to have a ton of this slathered on this part, far more than necessary. But that may be because I had the window regulator replaced at a dealer about 9 or 10 years ago, and perhaps they got carried away when they replaced the part. Just be sure to hand some old towels handy or a scraper to rub this nasty stuff off.
With the plastic interior panel removed, raise the rear quarter window. You can now easily see the lower portion of the main top bow piston sitting at an angle inside the hole. Just above, you will also see a black rubber grommet, about 1 1/2" in diameter, plugged into the metal of the side wall. This grommet is easily popped out with a screwdriver. And now -- at last -- you can see the object of all this interior removal work ... one of the two 40 T torx pins that hold each main top piston in place. As noted in other posts, these Torx pins were sealed with Loctite ... which leads me to a small digression and discussion of tools.
I'm no super mechanic, but I have a couple of old cars I keep running and generally own most tools one needs for auto work. Of course, every new challenge seems to require some dang tool I don't have, and that was the case here. I didn't own any metric Allen wrenches (hex keys) nor did I have a 40T Torx screw head. I bought both at a local hardware store.
Not having a proper driver, I inserted the 40T Torx screwhead into a 1/4" socket head and it fit nicely. Using an 3" extension and 1/4" ratchet driver, I put the ratchet-and-40T torx assembly through the hole and, of course, the 40T torx head promptly fell out ... and drifted down in the nether regions of the interior metal panel. Even using a magnetic retriever, I couldn't re-locate it. Argh. Back to the hardware store for another 40T ... their last one. This time, I put a bit of that sticky black gunk stuff (from the interior wall) inside the 1/4" socket, which served as a sort of glue to hold the 40T in place. It worked! As noted, the Torx pin was tight ... so, remembering Archimedes, I put a length of steel tubing over the ratchet drive arm to increase my leverage, and the Loctite seal was broken without stripping the Torx pin. After that, the torx pin came out easily.
However, rather than use my jury-rigged system, I urge you to purchase beforehand a proper set of metric Torx drivers that are designed to work with a standard ratchet wrench. Also -- and perhaps more important -- I urge you to buy a set of hex key (Allen wrench) drivers that work with a ratchet head, too. I used a standard "L" shaped 5 mm hex key to remove the pin that holds in the bow piston -- but it was very slow going, since I had to work blind, and by finger feel, withdraw and re-insert the hex key after each quarter turn in the tiny space inside the rear fender. Both a Torx and Allen key set can each be bought for about $16:
http://www.amazon.com/Neiko-Socket-1...pr_product_top
http://www.amazon.com/Neiko-Grade-13...bxgy_hi_text_b
Okay, back to the piston removal saga.
Although I'd removed one of the anchor Torx pins for the main top lift piston, I decided next to shift gears and pull the bow piston. This was done working exclusively from the open tonneau compartment. The bow piston (which lifts up the rear of the top when activated) was the cause of my top headaches, and I could clearly see the Febi fluid that leaked from it.
Bow Piston Removal
I began removing the cir-clip that holds in the upper pin, using an awl to pop the clip off. BTW, it's a good idea to first put some cloth in the hole area below so the cir-clip doesn't disappear down the well. Once the cir-clip was off, the pin should slide out -- but with the rear of the roof raised and held up by my bungie cord, the pivot pin cannot be withdrawn -- its clearance is blocked by the black steel top mounting bracket. To solve this problem, I removed the bungie cord and let the top go partly down into the storage well; this action extracted bow pin piston shaft, moving it high enough so that it gained clearance from the mounting bracket, and then the pivoting pin was easily removed.
Next, I tackled the 5 mm hex pin holding the rest of the bow piston. As I mentioned above in the discussion of tools, this was probably the hardest task of all since I was using a standard L-shaped 5 mm hex key. I'm right-handed and, working on the passenger side bow pin, I really wished I had an extra elbow located in the middle of my forearm! In any case, after a few attempts and working blind, I found I could use my left hand feel my way down to get the hex key inserted in the pin, then give it a twist. As with the Torx pin, the first turn was the hardest and I feared I might strip the pin. But lucky for me, it came loose without problems. But this pin is tightly fitted for its full length (about an inch) ... and it took quite a while (perhaps 20 minutes) to painstakingly pull and replace the L-shaped hex key for a quarter-turn, using my left hand while bent over half way. Hence my advice about buying a proper hex-key ratchet system first. The job would be done in about 2 minutes with the right tool.
Once that pin is out, the only things holding the bow piston in place are the two fluid lines. These are easily removed -- use an awl or small screwdriver to slide the little rectangular clips back, then gently pull on the lines. You can then pull the bow piston up -- but be careful, the passenger side has an electronic plug attached and you want to be gentle and don't let it get snagged on anything when pulling it from the car body.
Main Top Lift Piston Removal
I really thought this was going to be a bear ... but it was surprisingly easy, and far easier than the bow piston. In fact, I had it out in less than 10 minutes after removing the bow piston.
As noted, I'd already removed the 40T torx pin from the interior side. There's a second torx pin located directly on the other side of the piston -- and the only way to reach it is just like the bow pin ... reaching down in the limited space from the tonneau compartment. Using my trusty 1/4" ratchet drive containing the "glued in" 40T torx head, I again used my fingers and worked blind to guide the head into the Torx pin socket. Using my left hand, I pressed down and -- bang -- it freed up without stripping. I then used the ratchet to loosen the pin further -- unlike the bow pin hex bolt, this freed up nicely. I didn't remove the torx pin entirely -- thinking of the task ahead of re-inserting it, I decided I spare myself that. So I just backed it off enough so that the main top piston was released.
You will need to work inside the car to disconnect the fluid line at the bottom of the main top piston. And you'll see the fluid line is doubled-up and clasped to the piston by a round black rubber holder. This just slides off. Then, return to the tonneau area to disconnect the other fluid line at the top of the piston. Last ... there's a very simply semi-circular brass clip at the top of the piston shaft. Just slide the clip art sideways ... and the top of the shaft is easily released. You can then extra the entire main lift piston. Total time for this was less than 10 minutes!
With those two pistons out, I quit for the day. Before tackling the driver side pistons, I decided to order the tools I've mentioned. Once they arrive, I wil pull the rest of the pistons, and then I'll do a follow-up post on reinstallation.
Old Aug 16, 2011 | 10:53 AM
Timroperco's Avatar
1994 e320 Cabriolet
PDF: W124 Cabrio Hydraulic Cylinder R & R
After removing and reinstalling the hydraulic cylinders governing my 1994 e320 Cabriolet W124 soft top, I decided to work up a basic step-by-step DIY outline on the procedure and submit it here in PDF form.
This DIY guide borrows heavily from the post above, plus the previous posts and photos supplied by Vexed and others, and adds some pointers I learned along the way. For anyone attempting this job, I thought it might be helpful to have the DIY information in one printable form rather than consult multiple forum posts.
Although this job can appear intimidating, it's really not that bad. If you're comfortable with, say, removing spark plugs, you can do this job. Interior removal and gaining familiarity with the various cylinder locations takes up more time than anything else. Of course, as with any job, the proper tools are essential. Fortunately, you can obtain the right metric Torx and Allen Key ratchets for less than $30.
Good luck!
Old Aug 16, 2011 | 04:28 PM
RHW's Avatar
RHW
94 Wagon and 94 Cabriolet
I am expecting to need this, as I have two virgin top Cabs...so Tim, thank you for that writeup!~
Old Aug 16, 2011 | 11:07 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Great write up...much appreciated !!!!
Old Aug 19, 2011 | 06:27 PM
  #32
milyuns's Avatar
1998 E430, 1994 e320 Cabriolet
Great write up!!! I just did my cylinders a month ago and use Top Hydraulics, Hanns did a great job. I too found it a job most people can do if they can deal with the car looking ripped apart. Thanks for the PDF...
Old Aug 20, 2011 | 01:47 PM
  #33
vexed's Avatar
1995 E320 Cab; 2007 E350 Sport
It's very helpful for those undertaking this to have the benefit of Tim's excellent write up.
Old Oct 12, 2011 | 01:45 AM
  #34
KBelov's Avatar
E320 Cabrio
Re: Top Hydraulic Cylinder removal E320
This is fantastic write up. Let me add one correction however. There is no need to remove the black plastic under panel and deal with all that gunk. I do not have time to make my own write up, so I copied Tim's with all proper thanks and added my corrections how to avoid removal of the black panel. Do a google search "mbseals R129 A124" and you will find it. Thanks again Tim.
Old Oct 12, 2011 | 09:58 AM
  #35
Timroperco's Avatar
1994 e320 Cabriolet
Thanks, KBelov! I just tried searching for your additional comments but couldn't locate them. In any case (and now thinking back) I suspect you are correct in saying there's no need to remove the lower black plastic interior wall panel that's held on with screws and gunk.
The porthole in the metal side wall allows access to the 40T Torx pin that holds the main top cylinder. And once that Torx pin is removed (along with its mate on the other side) the entire cylinder can be retrieved from the access hole in the side of the tonneau area, where the bow cylinders are located. The hydraulic lines are long enough to permit this, and once the cylinder is out of the hole, the lines can be disconnected.
I actually learned this the hard way ... for after I'd installed my rebuilt main top cylinder on the passenger side and buttoned up the black plastic panel, I discovered I had a leak. Apparently I hadn't seated the hydraulic line properly to the bottom of the cylinder ... which meant I had to pull the dang thing again and fix the problem. This time, I decided I would try to extract the big cylinder while leaving the black plastic panel on. I removed the two Torx pins, then yanked the cylinder out through the upper hole as described above. Of course, I was helped this second time by knowing generally how things looked and worked down there -- knowledge I'd gained from removing the black plastic panel.
Also, I might add, if you drop one of the Torx pins when removing them, you'd likely need to pull the black panel to retrieve it from down below. And, I also found it was helpful to remove the black panel to place a trouble light down in that area, illuminating the interior of that spooky realm. But I was working in a dark garage and needed all the help I could get!
So, overall, I agree ... there's no practical need to remove the black plastic panel and deal with the gunk. I think the main reason it is there is to R&R the rear quarter window lift mechanism. But its removal can have its advantages, especially for the first-timer!
Thanks again!
Old Oct 12, 2011 | 11:32 AM
  #36
KBelov's Avatar
E320 Cabrio
Black panel removal
I tried to put a link here, but the whole post was removed by admins. Usually goodle pops up my place if you do the above searches. You can try to include my name Konstantin in the search. I am a "competitor" to somebody who made a business out of all this . I fixed my car own two cars in 2007 and tried to help others. Do physics research and teach students in real life. Has nothing to do with business
Back to the panel, ironically I will have to remove it now Somebody placed a dent on the right side of my car at UCLA parking lot. Large but smooth. The window does not go down fully. What did you use to seal it back ?
Old Oct 12, 2011 | 12:18 PM
  #37
Timroperco's Avatar
1994 e320 Cabriolet
OIC ... sorry about your fender bruise. I suppose you've already tried the old toilet plunger trick to pop it out? That's actually worked for me twice in years gone by (on other cars). There are also rubber dent pullers at most auto stores that use the same principle, and they can work too. Depends on the depth and location of the dent.
Sounds like your rear quarter window is being blocked by the dent, so beware of bending or wrecking the mechanism. My rear quarter panel window stopped operating when the cable on the regulator frayed and snapped. I had no decent area to work on it myself, so I took it to the MB dealer. Painful. Cost me something like $1,200 and they had it 2 weeks, waiting for a new regulator from Germany. Seems to me they could have simply replaced the cable but ... dealers don't "fix" things, just swap old parts for new.
As for the gunk ... well, I didn't add any more. There was plenty remaining! I just sorta smoothed around the excess and put the panel back on, screwing it tight.
