Headlight bulb/holder replacement 95 E320?
1995 E320 Cabriolet
One of our headlights went out and I noticed the holder that holds the bulb is brittle and falling apart and part is brown with burn marks. I assume I have to replace this part. Does anyone know the part # or where I can order it other than the local MB dealer? Brights on that light seem to work fine, regular beams don't.
It's a 95 E320 Cabriolet
As far as I know the bulb holder is not a seperate part and always comes with the complete assemby. The only thing you can get seperately is the glass. If you want to fix the holder only try the junk yard.
My guess: The "briddle" bulb holder looks like someone once used light bulbs with not siutable wattage.(standard is 55/60 Watts)
