'91 300E CEL, Code 16 Exhaust gas recirculation
300TE / 300E / 300CE
Anyone deal with this? I've looked at all my manuals (Hayens, Bible, '86 factory, & Motorbooks W124) and cannot find info on where and how to test for this error code. I've cleared the CEL and it's off for now.
Should I remove and inspect the pipe from the valve on the exhaust manifold?
found a thread on PeachParts
300e cel
Thanks Roy
pcv pipe clean
no leave the pipe at the intake alone. some how spray gumout into pipe let soak spray somemore take some vacume line,put it in pipe and blow the crudd into intake manifold,take off your intake from air cleaner to intake open butterfly(throttle) look down inside your a benz owner you can do it!!
