Check Engine Light ON Constantly. Dealer Says It's the ECU Computer!
there should be error code on it, try to erase it then see if it happens again.
BTW, is there any difference, other than the light on? do you feel anything strange?
Cause my car has the same problem they said it's the ignition control module thar went wrong...but there is nothing wrong with my ignition?! and the error code can be erased, but the light will come back on after a short period.
This past week they told me I'm kind of wasting their time so either I change the computer or they're going to start charging me $150 for check/re-set.
The car drives well with no major problems other than that I may need to replace the shocks.
Off the topic a little bit, I noticed that your location says Taiwan. Are you there right now? I was thinking about going there in a few weeks but how bad is SARS there? I ordered some 3M N95s and it should be here tomorrow.
Anyway, thanks.
