Help.. just replace neutral switch
Old Jun 25, 2010 | 01:36 AM
roach_juts's Avatar
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
hello
before my car died, i was able to start the car when i put it into neutral,
i did it for 6 months then today the car just wont start, so i replace the neutral switch, but the car still wont start???? the thick connector that you plug in the neutral switch has a crack in it .... is this the reason my car car is not starting ? it started once since i replace the switch( on park) after that in dead.
is there other reason my car wont start ?
is the alignment of the switch impt ?
is the bushing on the stick shifter needs to be aligned or replace ??
