sway bars, anyone?
L8
Do a search for SWAYBARS and look for ksing44.
He's obsessed with them!
Here's a few to start you off...
https://mbworld.org/forums/showthrea...light=swaybars
BTW ksing44, what DID you end up fitting?
When I break down and get the bars, I think I will go for E500 rear bar (124-323-77-65) and "limo" front bar (124-323-77-65). The dealer thought that he could get everything I wanted, so OEM upgrade might be the best way to go. Eibach is to be discontinued, but Luke at Tirerack though he would have a few more kits in April.
looking at the listing of sway bars for the 124, there's nothing on here that says it won't fit a 4Matic. Would the one for the 90-92 300E fit my '91 300 4Matic? (Part number: 124-323-55-65)
L8
I have since received and installed the correct Sportline bar on the front. I am waiting to have a mechanic install the rear bar. There is a noticeable difference on twisting, winding roads with just the front bar installed. It is not a sports car but the dip on curves is reduced enough for the car to feel more stable and in control. Ride on straight roads not affected. I have considered the Sport Bilsteins for a future mod but like the ride on the highway with the standard shocks.
I have seem specs for diameters of all sway bars for the 124 series except for the Sportline bars, so I don't know how they compare to the 500E but my guess is that the Sportline bar is lighter duty than that found on the 500E.
One question I do have: Are the Sport Bilsteins only for the shorter Sportline springs? Do they have the same length of extension as the standard U.S. issue shocks?
Swaybars
http://www.mercedesshop.com/shopforu...threadid=57000
Bilstein shocks
http://www.mercedesshop.com/shopforu...threadid=53458
Lowering springs
http://www.mercedesshop.com/shopforu...threadid=60502
any difference between sportline sway bars and e500 bars?
You will find a link from "gsxr" that has an amazing, complete list of the bars for a W124. The link is http://www.meimann.com/images/mercedes/W124_stuff/ and then you download the file MB_124_swaybars.xls or MB_124_swaybars.pdf After you have that file and the install directions also found at that link, you will know about all there is to know about swaybars for a W124.
