Drive shaft support bearing question
Old Jul 20, 2010 | 03:27 PM
dth0183's Avatar
1995 E320 sedan
So on my newly acquired 95 e320 I began hearing a clunking...diagnosed as bad front flex disc as I am sure many of you have replaced.
I decided while at it to have the rear flex disc, transmission mount, and center support bearing replaced.
I think I mistakenly ordered redundant parts and was hoping someone could take a look. I thought the support and bearing were separate, but when I look at the second part it seems to include both bearing and support. Can I use only the second part and send back the first or do I need both?
The first part is: National Drive Shaft Center Support Bearing #106CC
the second part is: Uro parts drive shaft center support #1244100281
Can't wait to get this done and get to work on the EGR!
Old Jul 20, 2010 | 09:21 PM
dth0183's Avatar
1995 E320 sedan
also...if both parts would work is one better than the other?
