Is this problem normal?
Start with the ignition switch.
Possibly it was replaced and was wired incorrectly.
The items that remain energized in your car should not work with the ignition switch in the off position.
Ed A.
I myself found this out the hard way when trying to connect wires in my own tail lights, to make double tail parklights. The result I got was a constant ignition, even when the key was out..
I guess a short cirquit in this area could cause the same effect..
Atleast it is worth to check it up. Try to unplug both tail lights for starters..
