Mechanic says 300TE is done but runs well?
It has over 200k and I just replaced all the tune up parts and O2 sensor so I was hoping it would pass. I thought worse case it would need a cat.This is my dad's second car so I'm considering doing the valve /HG myself or pay a home mechanic who may do it for under $1k. I considered replacing the valve seals but read the mileage should be under 150k. It may be time to "practice" since my wife's '91 is starting to consume oil...
If you're going to replace the valve seals, you might as well do a full valve job. If you have the engine apart once and realize it still doesn't pass smog, you'll be smacking yourself all the way to the bank.
