belt tensioner
Old Sep 19, 2010 | 03:40 PM
smoothaseggs's Avatar
300E
belt tensioner
is the tensioner automatic or is it adjustable? do they go bad? i have screwed the adjuster left and right and not much seems to be happening. the bearing sounds and feels ok just not enough tension on belt
Old Sep 21, 2010 | 01:20 AM
300E
tried adjusting the tensioner and now the bolt has come out and wont thread back in!
Old Sep 21, 2010 | 05:51 AM
QVHK's Avatar
'90 300CE M103 Manual '93 Alfa 164 QV24 '05 Jaguar X350
Probably wrong sequence in loosening and tightening the tensioner. You will probably need a new tensioner as the bolt on the thread on the old one is now bad. The Sticky at this Forum has a DIY section on tensioner?
Old Sep 21, 2010 | 09:01 AM
kwontumspeed's Avatar
93 500e<P>94 E320T "Sportline"<P>90 FJ62
All the signs of a bad tensioner. Hopefully you didn't thread the bolt out so much that you bent the bolt. These tensioners are a poor design, you can search and find tons of post on this same opinion. Buy a new one. It's a DIY with some patience as most of the bolts are pretty tricky to get to. Do a search, as QVHK suggested. There are some good write ups but I don't think there's one on the sticky...
Old Sep 21, 2010 | 10:59 AM
300E
i'll take a look thanks
