WANTED: 1995 Mercedes E320 Convertible Top Control Module
Old Sep 30, 2010 | 07:13 PM
crichie's Avatar
1994 S500 Coupe 1995 E320 Convertible
Hello All,
I am looking for a soft top control module for my 95 w124 cabriolet. The mercedes part number is 1248205826 I believe also the w129 module might be similiar.
Old Oct 1, 2010 | 12:36 PM
joef's Avatar
S500
check you number. I know of 124 820 40 26 & 45 26, but not 58 26
I have a 40 26 available.
Old Oct 1, 2010 | 12:57 PM
crichie's Avatar
Re: w124 Cabriolet top control module
I am sure that is the correct number. I just wanted to make sure I have the right module for the top. This module was located under the rear seat cushion in the middle and has a 16 pin connector.
Old Oct 1, 2010 | 05:56 PM
KoosKoos's Avatar
1995 E320,2002 S430,2008 E550,2001 E430,2002 C32
w124 E320 Cabrio
The top module is part# 124-820-40-26 UP TO B993871
and 124-820-45-26 from B993872.
The 124-820-58-26 is the module for the rear roll bar.
Old Oct 1, 2010 | 06:24 PM
crichie's Avatar
That makes sense the roll bar module would be under the rear seat. I removed the module and it makes a clanging sound like there is some loose change in the box. I removed the cover and found a component on the circuit board makes a sound like something is loose in side the component. The component is a beige/white clyindrical part soldered to the board. It has a Bosch logo stamped on it with a number bearing 2287328601. Also could someone please tell me the location of the soft top control module. Thanks for everyones help. I really like this car a lot.
Old Oct 1, 2010 | 06:44 PM
KoosKoos's Avatar
W124 CABRIO
Its under the rear seat on the right side.
Old Oct 1, 2010 | 07:39 PM
crichie's Avatar
Thanks for that info: I just looked under rear seat to the right and realized there is no top module. I was saw three cables that had absolutely nothing plugged in. One of the cables looked like an ECU cable end. Could someone please tell me what computers or controll modules should be under the rear on the right side. Thanks.
Old Oct 3, 2010 | 01:37 AM
pifcat2's Avatar
300TE / 300E / 300CE
Your top controller will cost over $2k, you might want to ask the PO what happened to it.
Old Aug 16, 2017 | 02:38 PM
Bato Arsovic's Avatar
Mercedes 124 cabriolet
I nede a 124 820 40 26 Can I use 45 26 to My car
Old Aug 16, 2017 | 02:57 PM
I need a 124 820 40 26 Can I use 45 26 to My Car
Old Nov 10, 2020 | 10:09 PM
andrewmcqueen's Avatar
E320 convertible
E320 Cabrio top module
I need a module as well . do you have any Leeds for me .Andrew 480 717 8088 thx
Hello All,
Old Nov 23, 2020 | 01:39 AM
Renaissateur's Avatar
'94 E320 CV Sportline/AMG
WANTED: 1995 Mercedes E320 Convertible Top Control Module repair
This guy is very good at repairing old analog MB modules, and he's cheap. Lives in the San Fernando Valley near L.A.
Give him a call:
Artyom Galoyan
818-331-4132
Old Mar 14, 2021 | 08:55 PM
Lasid3's Avatar
1995 E-320 Cabriolet convertible
Any luck on a convertible top controller or anyone have any leads? I also have a ‘95 E320 W124.
Old Mar 16, 2021 | 01:04 PM
Lasid3's Avatar
Hello All,
Any chance you might know where to find a convertible controller for an E320 w124?
Old Mar 16, 2021 | 01:07 PM
Lasid3's Avatar
By any chance do you know where to find a convertible controller for an E320 W124?
124 820 45 26
Old Mar 17, 2021 | 07:37 AM
Habil's Avatar
93 W124 2.5TD
124 820 45 26
This company in Germany might be able to repair your controller. https://www.eps-elektronik.com/merce...65_811-898.php
Old Mar 17, 2021 | 06:23 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
124 820 45 26
Have you check around with your local PnPs, for 124.066s sitting around?
Old Sep 15, 2022 | 09:48 AM
tonym1958's Avatar
1993 MERCEDES E320
93 E320
Hi I need a 124-820-40-26 do you still have one? Is it good?
